where can I get Traliling arm bushing for an 88 CRX Si
Old Feb 14, 2004 | 06:37 AM
Renegade's Avatar
Default where can I get Traliling arm bushing for an 88 CRX Si
Even Majestic honda said I have to buy the entire trailing arm...
I want to avoid aftermarket (sliding ) hard bushings.
Any leads are extremely appreciated
thanks
Old Feb 14, 2004 | 08:50 AM
Mugen Dom's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (Renegade)
u can get energy suspension replacements if they dont offer them for the 88 crx get em for the ITR they are the same.... its a BIATCH to replace em just so u know but on the bright side they solve alot of problems if urs are broken....there was a post a while back with directions.....but just remember when ur doin this its worth the hassle
Old Feb 14, 2004 | 10:39 AM
Renegade's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (jason_alt)
I have a 20 ton press, taking them out is not a problems. Pump pump pop its out
Old Feb 14, 2004 | 11:06 AM
Renegade's Avatar
I remember reading that thread, I was subscribed but for some reason I stopped getting e-mails from HT for a long time and lost track of the posts. Thanks
Old Feb 14, 2004 | 11:17 AM
CRXRageD's Avatar
Mugen hard rubber is what you want. better than poly and a hell of a lot safer.
Old Feb 14, 2004 | 11:20 AM
rsbad454's Avatar
http://www.summitracing.com or http://www.suspension.com and order the master poly kit. all the bushings are easy to replace and dont need a press. Use a little propane torch and burn them out. Just have a hose or bucket of water ready.
Old Feb 14, 2004 | 01:44 PM
b16_madman's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (rsbad454)
read the link posted above dood, no one wants to do poly for those rear trailing arms
Old Feb 14, 2004 | 02:26 PM
EG8R's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (B16_madman)
I did mine with poly.... *shrugs*
And why is it that no one wants to do them that way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMB16Ahatch &raquo;</TD></TR><TR><TD CLASS="quote">u can get energy suspension replacements if they dont offer them for the 88 crx get em for the ITR they are the same.... its a BIATCH to replace em just so u know but on the bright side they solve alot of problems if urs are broken....there was a post a while back with directions.....but just remember when ur doin this its worth the hassle</TD></TR></TABLE>
Yes they are available for 88's. The trailing arm is the same. The rear lower arm is not. ES makes 88 rear lower arm bushings. You just have to know how to read nad pay attention to what is on their site.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXRageD &raquo;</TD></TR><TR><TD CLASS="quote">a hell of a lot safer.</TD></TR></TABLE>
What do you mean? I did mine without using fire....
Modified by skelly ed6 at 9:01 PM 2/14/2004
Old Feb 14, 2004 | 06:39 PM
EG8R's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (skelly ed6)
Anyone care to answer?
Old Feb 14, 2004 | 08:39 PM
baruba's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (CRXRageD)
ive had the same dilemna my rta rubber is shot with huge tears in the rubber. im so ghetto i filled the tears with go op so it might hold it a bit longer.
Im probably gonna end up with oem or if i can find the mugens, but ill get urethane sway bar b's in pu.
Old Feb 14, 2004 | 09:13 PM
CRXRageD's Avatar
if you want the Mugen trailing arm bushings OPM Motorsports has them for $115.
http://www.opmautosports.com/p....html
Old Feb 15, 2004 | 05:39 AM
scdarksol's Avatar
$55 a piece at the dealer.
Old Feb 15, 2004 | 08:14 AM
EG8R's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (scdarksol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scdarksol &raquo;</TD></TR><TR><TD CLASS="quote">$55 a piece at the dealer. </TD></TR></TABLE>
$38 CDN for ES.... FOR BOTH!
Oh ya, no ones asnwered my question yet.... Guess they can't back their statement.
Old Feb 15, 2004 | 11:13 AM
Renegade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason_alt &raquo;</TD></TR><TR><TD CLASS="quote">This should help you..
https://honda-tech.com/zerothread?id=493789</TD></TR></TABLE>
Follow Jason_alt link it will answer your question. Good post
Old Feb 15, 2004 | 11:21 AM
Doctor CorteZ's Avatar
this forum makes my head hurt , did anyone even read the link posted ?
it spells it out for you why the poly ones are bad , and just an FYI , the master kit doesnt come with the TA bushings anyway...
Old Feb 15, 2004 | 11:39 AM
Jester88Si's Avatar
Which side do you need? I have a spare driver's side trailing arm off my 88 crx si great condition I pulled it to swap to newer civic trailing arms. PM me if your interested....
Old Feb 15, 2004 | 05:59 PM
EG8R's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (Jester88Si)
Ok I read some valid points.... I would like to see for myself and then I will go from there.... But for now they seem to be fine....
I wonder why you can't get bushings seperate.... Last I heard we could get them seperate here *shrugs*
Old Feb 15, 2004 | 09:42 PM
schuey10101's Avatar
Maybe the newbie can help you out here.
Try this
52385-SR3-000
I think that is what you are looking for
Old Feb 16, 2004 | 05:12 AM
rsbad454's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (schuey10101)
how lame............poly bushings are awesome.....i run them in my teg and my prostreet truck. i would never waste my time with anything else if your going through the trouble to take them out and replace them. make sure you run the black bushings and not the color ones do to the fact the black ones are impregnated with graphite and wont squeek as much.
Old Feb 16, 2004 | 08:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">i would never waste my time with anything else if your going through the trouble to take them out and replace them. </TD></TR></TABLE>
you should read the post , the solid poly TA bushings cause suspension bind , they dont allow movement on both axis resulting in a very unpredictable car , under bind your springs go infinite and cause snap oversteer , I doubt that anyone wants that.
Old Feb 16, 2004 | 10:15 AM
rsbad454's Avatar
Default Re: where can I get Traliling arm bushing for an 88 CRX Si (Doctor CorteZ)
hmmmmm, i never heard of this.........where is the proof that poly bushings cause such an action?
Old Feb 16, 2004 | 01:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">hmmmmm, i never heard of this.........where is the proof that poly bushings cause such an action?</TD></TR></TABLE>
look at the trailing arm , common sense will tell you it needs to move on two planes.
something a completely solid bushing in that location will not allow.
Old Feb 16, 2004 | 02:37 PM
CRXRageD's Avatar
visit the http://www.theoldone.com in the forums. TOO has the answer.
Old Feb 16, 2004 | 06:16 PM
rsbad454's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">
something a completely solid bushing in that location will not allow.</TD></TR></TABLE>
they arent that solid.......the poly bushings under load do move some.....the durometer of the kit is softer than you think.....i installed the entire kit into my 89 teg and it works great.........some people on here are saying they like them and others they dont.......i can picture what your saying but the rear will still have travel in the other plane. too much hear say IMO
Old Feb 16, 2004 | 06:28 PM
EG8R's Avatar
89 Teg's have a different rear suspension set up.... No solid rear axle on 88+ Civics and 90+ Teg's....
kelsodeez
14
Jan 1, 2011 09:16 AM
xjunkii
Suspension & Brakes
Apr 19, 2008 03:49 AM
apexinghonda
33
Apr 14, 2005 07:46 PM
spettinger
Jul 1, 2003 06:23 PM
HondaRcB
Feb 14, 2003 03:20 PM
