msd 2-step switch??
Old Feb 13, 2004 | 11:07 PM
egturbo's Avatar
Default msd 2-step switch??
hey wassup guyz. i've had my msd 6 al 2-step for a long time now. bought it used with no msd switch so i rigged it with some radio shack clutch switch. lol. doesnt work to good. do u guys have pics of the original switch that comes with the 2-step?
and where i can get one? TIA
cheapo switch with the metal clip broken off
where i put it in back of the pedal
where it is now. on the ground lol..
Modified by egturbo at 7:32 PM 2/14/2004
Modified by egturbo at 7:33 PM 2/14/2004
Old Feb 14, 2004 | 12:15 AM
egturbo's Avatar
Default Re: msd 2-step switch?? (egturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo &raquo;</TD></TR><TR><TD CLASS="quote">hey wassup guyz. i've had my msd 6 al 2-step for a long time now. bought it used with no msd switch so i rigged it with some radio shack clutch switch. lol. doesnt work to good. do u guys have pics of the original switch that comes with the 2-step?
and where i can get one? TIA</TD></TR></TABLE>
Old Feb 14, 2004 | 01:13 AM
egturbo's Avatar
qwr
Old Feb 14, 2004 | 05:00 AM
SpeedDreamz.com's Avatar
Why doesnt your rigged up switch work? Do you have any pics? Is it a clutch switch?
Old Feb 14, 2004 | 06:57 AM
DOHCarp's Avatar
When I purchased my MSD 2-step it did not come with a switch. I bought an NOS micro switch and bracket then mounted it under my clutch pedal. You can also use a relay to with your cars present clutch switch(factory clutch switch is a negative signal need rlay to change to positive) wire that up and your set.
Old Feb 14, 2004 | 10:39 AM
egturbo's Avatar
Default Re: msd 2-step switch?? (30psiCiv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psiCiv &raquo;</TD></TR><TR><TD CLASS="quote">Why doesnt your rigged up switch work? Do you have any pics? Is it a clutch switch?</TD></TR></TABLE>
yeah ill get some pics of it. i use black take to tape that lil metal piece to the clutch. but it broke off. some cheap thing i got at radio shack. lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp &raquo;</TD></TR><TR><TD CLASS="quote">When I purchased my MSD 2-step it did not come with a switch. I bought an NOS micro switch and bracket then mounted it under my clutch pedal. You can also use a relay to with your cars present clutch switch(factory clutch switch is a negative signal need rlay to change to positive) wire that up and your set.</TD></TR></TABLE>
im noob. got pics?
Old Feb 14, 2004 | 04:32 PM
egturbo's Avatar
pics posted.
Old Feb 14, 2004 | 04:43 PM
hybridreams's Avatar
Ha, yeah that's pretty shitty.
Here ya go:
https://honda-tech.com/zerothread?id=585755
Old Feb 14, 2004 | 04:58 PM
NitrousB.I.G.'s Avatar
Default Re: msd 2-step switch?? (hybridreams)
I used one of the factory clutch switch either the starter disable switch or the cruise switch I cant remember but im pretty sure that it was the starter disable. I also put in a second switch in line on my console that is used to disable the two step for burnouts. With the way that its setup I dont have to lift the entire quarter mile, the clutch switch alows you to shift at full throttle without over reving and have still have the launch rpm feature. The thing I like about this setup is its almost idiot proof.
Old Feb 14, 2004 | 09:42 PM
V-SPEC 1's Avatar
Default Re: msd 2-step switch?? (NitrousB.I.G.)
I hook mine up to the factory switch. works great so far.
Old Feb 14, 2004 | 10:27 PM
egturbo's Avatar
Default Re: msd 2-step switch?? (boostedb20vtec)
damn. so i should ditch my dinky switch and just wire it up to the stock wires? HOW TO?
Old Feb 14, 2004 | 11:38 PM
I personally don't like using the clutch switch for the 2 step. I prefer the push button setup.
Old Feb 15, 2004 | 09:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridreams &raquo;</TD></TR><TR><TD CLASS="quote">I personally don't like using the clutch switch for the 2 step. I prefer the push button setup.</TD></TR></TABLE>
Why is that?
Old Feb 15, 2004 | 09:50 AM
egturbo's Avatar
Why is that?</TD></TR></TABLE>
my friend has that. but personally i like the clutch switch better. anyone got diagram on how to wire it up to the stock clutch wires?
Old Feb 16, 2004 | 10:19 AM
egturbo's Avatar
my friend has that. but personally i like the clutch switch better. anyone got diagram on how to wire it up to the stock clutch wires?</TD></TR></TABLE>
Old Feb 16, 2004 | 04:37 PM
No technical reason or anything, I would just rather have control of my 2 step at my fingertips.
Old Feb 17, 2004 | 10:26 AM
hybridnorth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousB.I.G. &raquo;</TD></TR><TR><TD CLASS="quote">I used one of the factory clutch switch either the starter disable switch or the cruise switch I cant remember but im pretty sure that it was the starter disable. I also put in a second switch in line on my console that is used to disable the two step for burnouts. With the way that its setup I dont have to lift the entire quarter mile, the clutch switch alows you to shift at full throttle without over reving and have still have the launch rpm feature. The thing I like about this setup is its almost idiot proof.</TD></TR></TABLE>
this is the way i did it too, it works great
arm the switch, use 1 relay, i got everything wired so when my e-brake is up it acts like launch control, drop the ebrake and the clutch switch is for full throtle
Old Feb 17, 2004 | 10:57 AM
Kataku2K3's Avatar
Default Re: msd 2-step switch?? (hybridnorth)
I've never wired it up with a seperate switch as you have posted, nor have I done it over the stock clutch switch(es)... Typically I tap off the E-brake gnd. use a relay to reverse the polarity, then send the 12V+ to the MSD box to activate the 2-step just as you normally would... It just works easiest for us since most of the cars are on bigger slicks (like to roll easy at the line) and if you're preloading the clutch a little at the line you need the E-brake up anyways... If we're running an Innovative MSBC (clutch switch output only for gear dependant boost levels) this is how I wire it, below is a diagram I made awhile back... Very simple and it seems to work fine... Just my $0.02
Modified by Kataku2K3 at 6:40 PM 2/17/2004
Old Feb 17, 2004 | 05:02 PM
Garcia-Racing's Avatar
msd 2 steps dont come with a switch. I went to a local electronics store and bought a momentary push button switch and mounted it on my steering wheel. works great, can be used for burnouts that way, too.
Old Feb 17, 2004 | 10:10 PM
egturbo's Avatar
Default Re: (TGARCIARACING)
so confusing. i want something easy to wire.
Old Feb 17, 2004 | 10:22 PM
egturbo's Avatar
Default Re: (egturbo)
so hey. a 2-step also has full throttle shift right?
Old Feb 17, 2004 | 10:27 PM
HotRodTeg's Avatar
You can hook the 2 step up to full throttle shift if you us the factory clutch switch and a relay.
Old Feb 18, 2004 | 07:25 AM
spooler's Avatar
My Haltech E6K has a 2-step feature built into it. If I wire it up using the clutch switch (NSS) and set it at 6500RPM, what happens when I put the clutch in at a 8000RPM shift? Will anything odd happen like big *** puffs of unburnt fuel?
Old Feb 18, 2004 | 07:54 AM
Kataku2K3's Avatar
Default Re: (spooler)
That's one thing I've always considered and probably the reason I don't wire the 2-step into the clutch switch... When I get time I'm going to work on a circuit that allows you to push a button at the line, step in the clutch to activate the 2-step, then after you launch, it turns off... "If the motor isn't actually trying to rev up (i.e. you're off the gas) and the 2-step is activated which just pulls timing at a fixed rev limit does it seem like your motor should run different when you're already over the set rpm?" I haven't actually tried this but as long as you're uplifting on shifts I think you'll be okay... Not sure tho, hehe... If you run it let us know how it does... Latez, -Adam
Old Feb 19, 2004 | 11:36 AM
egturbo's Avatar
fcvgdxfg
