Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Spark Plug color on your track only cars?
Old Feb 13, 2004 | 06:50 PM
577HondaPrelude's Avatar
Default Spark Plug color on your track only cars?
What do your spark plugs look like after a year of racing? This past summer I converted my car into a track only car and 90% of the miles on it came while out on the track. I just replace the plugs the other day and they were black. No build up or anything, just a dry flat black color. They looked normal in every other way. The car also seems to running just fine.
Before the car was a track car the plugs used to turn a nice dark tan color. Is the black color I have now because the car operates under full throttle most of the time thus the A/F is a bit rich? Is this a normal color for the plugs on a track car or should they still be a dark tan color?
Old Feb 14, 2004 | 12:27 PM
Default Re: Spark Plug color on your track only cars? (577HondaPrelude)
anyone?
I Just want to know if your race cars have black or tan plugs when they come out.
Old Feb 14, 2004 | 02:32 PM
civicrr's Avatar
Sounds like you are running rich.
My plugs are a nice tan color.
Old Feb 14, 2004 | 05:00 PM
Default Re: Spark Plug color on your track only cars? (civicrr)
but your car should run a bit rich when at full throttle right? 14.7 a/f would be way too lean for full throttle. Was the tan plugs out of a car used for racing only?
Thanks for the help. I'm just trying to figure out if I have a problem or not.
Old Feb 14, 2004 | 06:10 PM
civicrr's Avatar
Track car only. My a/f isn't running that lean. I have had the ecu tuned using the Hondata system.
Old Feb 15, 2004 | 05:45 AM
jsi's Avatar
jsi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">
The H22 does run quite rich under WOT plus it's an oil burning pig under hard use which doesnt help either. When I used to track my 98SH, it was not uncommon to go through a quart of oil in 50-60 track miles. With &lt;30K miles on the motor. The plugs would be as you described after a track day but would return to normal dark tan color after a few days street use...
TunerD16z6
Apr 16, 2008 07:23 PM
2DoorBandit
Jan 30, 2007 02:53 PM
Lei Siew Long
Apr 7, 2004 04:18 AM
93H22ACX
Mar 13, 2003 05:13 PM
Canuk_SiR
Jul 31, 2002 07:35 AM
