Need HELP picking turbo.
Old Feb 13, 2004 | 06:42 PM
beautifulblue's Avatar
Default Need HELP picking turbo.
I need some help picking out the right turbo for my civic. Here's my specs:
b16a2 bored to 1.7
stock vtec head
Ross 9:1 pistons
Eagle rods
Re-balanced crank
650cc injectors
225 l/hr fuel pump
STR fuel rail w/ pressure reg.
hondata
tial 38mm wastegate
i think this should be enough.
My goal is 350whp. This is going to be a daily driver too, so i want a pretty good spooling turbo, maybe 3000-4000 max boost range.
Gimme your suggestions guys!!! thanks
Old Feb 13, 2004 | 10:32 PM
PrecisionH23a's Avatar
Default Re: Need HELP picking turbo. (beautifulblue)
A t3/t04e 50 comp and .48 a/r turbo should be able to do it with around 14-15psi of boost. It's always good to get a bigger turbo though... I would suggest maybe looking into running the Precision SC32 turbo. Ball bearing is a nice option, but with compressor wheels that fast traction is really going to kill you in 1st and 2nd gear.
Old Feb 14, 2004 | 09:14 PM
Default Re: Need HELP picking turbo. (PrecisionH23a)
ok cool. What about going bigger though? like .63 a/r turbine and .60 on the compressor? And anything on wheels? I definately want to go ball bearing.
Old Feb 14, 2004 | 10:23 PM
b18b1hmtlove's Avatar
.63/.60 60 trim........
Old Feb 14, 2004 | 10:40 PM
MrEG6er21
Guest
Posts: n/a
Default Re: (b18b1hmtlove)
One that comes to My mind is the Patatoe Turbo. Do your research if you dont know about it and you will thank me later.
Old Feb 14, 2004 | 10:42 PM
Boostin Ex's Avatar
Default Re: (HNDAPJT21)
Go big or dont go at all
Tmnjlb123
Sep 16, 2014 03:34 AM
89civic1.8T
Feb 3, 2004 09:32 AM
xxxmikenicexxx
Jan 20, 2004 11:45 AM
92lSilude
Oct 7, 2003 07:57 PM
PROFILES2000
Mar 8, 2002 07:51 PM
