OBD1 conversion problems need smart help?
Old Feb 13, 2004 | 04:30 PM
100whplusperliter's Avatar
Default OBD1 conversion problems need smart help?
I have a 91 crx si with a b16a sir
I have almost converted to 0bd1 with a new td44u, 4 wire o2, hondata s200 in a p28 and a conversion harness. and kept the si injectors
I have the car running but badly it is giving a #9cyp and #16 injectors codes.
I have checked
the resistance in the injectectors good 2 ohms
the voltage at connectors 12.8
the injector wires at ecu are all good
the resistance of distributor cyp is 349.3-353.5 (when a little cold out at different times) at all connectors to ecu
the resistance of tdc is 378.00 ecu
the ckp is 378.00 also at ecu
no continuity to grond
everything is pinned correctly
have spark, fuel and drive at injectors
and tried an old engine harness same codes
I have run out of things to check
Could the td44 not be compatible for the obd1 distributor. Is their another distrubutor I could try?
Any Ideas or things to check please help
Thanks,
Jack
motoguy126
Jun 26, 2010 04:24 PM
4GE4YA
Aug 9, 2007 11:17 AM
Boosted2000B16
Jan 15, 2006 06:14 AM
B20Monster
Feb 3, 2004 08:11 PM
Civicboy
Jul 7, 2002 07:36 PM
