RSX Type-S VS SI
Old Feb 13, 2004 | 04:28 PM
ahealthyguy's Avatar
Default RSX Type-S VS SI
I was told that the SI and the RSX have the same engine components. And althought the RSX is 200 and the SI is 160 that you can get the SI to achieve 200 HP ez since they have most of the same stuff. I was wanting to know how I could go about tweaking my SI to run like the RSX
Old Feb 13, 2004 | 04:42 PM
Boost Ambassador's Avatar
Default Re: RSX Type-S VS SI (ahealthyguy)
Holy **** your asking how you can tweak your SI to handle a Type S? You are a true trial user....
Old Feb 13, 2004 | 05:06 PM
andyep3's Avatar
It's easy to make an Si run like an RSX-S.
Find and RSX-S, pop the hood and take the
engine out. Replace the Si's engine with that
one and voila! you're done.
Seriously, the *base* RSX and the Si have the
same engine. The K20A2 (RSX-S) and K20A3 (Si) engines are similar, but not enough to just
add on some parts and be equal. Browse this forum more and check out k-series.com, sounds like you've got plenty of reading to do.
Old Feb 13, 2004 | 05:10 PM
dwnshft02's Avatar
Are turbo, nitrous or engine swaps considered "Tweaking"
Old Feb 13, 2004 | 05:40 PM
Peking's Avatar
Default Re: (andyep3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyep3 &raquo;</TD></TR><TR><TD CLASS="quote">It's easy to make an Si run like an RSX-S.
add on some parts and be equal. Browse this forum more and check out k-series.com, sounds like you've got plenty of reading to do. </TD></TR></TABLE>
Add certain parts and you might be more than equal. And you do have alot of reading to do. K-series, Ephatch, hell clubrsx, and here.
Old Feb 13, 2004 | 07:33 PM
^jefs0ng's Avatar
Banned
Default Re: RSX Type-S VS SI (dwnshft02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnshft02 &raquo;</TD></TR><TR><TD CLASS="quote">Are turbo, nitrous or engine swaps considered "Tweaking" </TD></TR></TABLE>
I believe so but he wanted to run like one not light years ahead of one!
Old Feb 13, 2004 | 08:45 PM
MI4eg's Avatar
hahahahahahahaaa
Old Feb 13, 2004 | 09:28 PM
EP3rAcEr's Avatar
k20a2 with hondata ecu... than you will have a chance to beat the type-s
Old Feb 14, 2004 | 05:05 AM
B18CXr's Avatar
use the search button first...
Kold
29
May 13, 2012 04:03 PM
way2much
20
Dec 28, 2007 05:37 AM
Halo
Nov 13, 2001 03:00 PM
Civic Hatch Boy
20
Oct 18, 2001 04:56 PM
