more oil flow for an extra oil cooler kit?
I am thinking of installing an extra oil cooler kit.. something like this
http://www.jcwhitney.com/webap...26592
would I need extra oil flow to compensate? If so, what kind of aftermarket oil pump should I get to compensente the flow?
any other oil cooler kits that are better them the b&m?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScorpioX »</TD></TR><TR><TD CLASS="quote">would I need extra oil flow to compensate? If so, what kind of aftermarket oil pump should I get to compensente the flow?
Flow will be the same. Maybe a 2 psi drop in oil pressure could be expected, and thats not much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScorpioX »</TD></TR><TR><TD CLASS="quote">any other oil cooler kits that are better them the b&m?
Many different coolers are out there, but they can be quite expencive. You should also consider an oil thermostat if this is going into a street car, and that is not included in the b&m kit.
I've seen a couple kits in the classifieds lately, you should search for them.
More info can be found by searching the ITR and RR/AX forums.
92civichatchsir
32
Aug 28, 2005 03:10 PM
