Fuel Pump Replacement
I have a 97 EK civic hatch that originally had a D16. I'm swapping in a H22 from a 96 prelude and my understanding is the civic stock fuel pump doesn't have enough pressure and/or volume for the prelude motor????
What fuel pump/regulator can i use and still not affect the fuel gauge/sender???? Does it have to be an internal pump or can i use an external pump?? Also where is the current regulator, is it an integral part of the stock pump or externally located??
I don't want to mess up the stock fuel gauge and the new motor is basically stock except for headers and ignition.
Just get a Walbro. I have a 190lhr on my turbo D and it works just fine. A little loud, but other than that it's all good. You can also upgrade to a 135lhr pump from a SI/GSR, etc.
You need an intake fuel pump.
get an 'R pump, or the walbro is always a good upgrade. i have a 255 in mine. it wont mess with the stock gaoge or sender. it is a direct replacement. easy. under the rear seat. cake.
and just in case its not that straight forward to you, heres a quality write up, courtesy of c-speed.
http://www.c-speedracing.com/h...p.php
i would get a walbro as well but i think your pump will be fine. i ran a stock cx fuel pump in mine for a long time and i was running 12 sec et's on 10psi with it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sector9guy »</TD></TR><TR><TD CLASS="quote">and just in case its not that straight forward to you, heres a quality write up, courtesy of c-speed.
http://www.c-speedracing.com/h...p.php</TD></TR></TABLE>
link doesnt work. but basically if i buy that walbro 255 ill be set, nothing else will need to be tampered with or changed? sounds easier than i had originally thought. i would like to read more up on that site, but the link isnt working for me.
