Problems with itr calipers on 92 hatch
Old Feb 12, 2004 | 05:40 PM
DALE-EK4's Avatar
Default Problems with itr calipers on 92 hatch
I just put my itr brake calipers on my 92 hatch. They have been bled correctly numerous times and my brake pedal is on the floor. It does have pressure once you get there and it stops but i have to push them almost to the floor to get them to do anything. Is there an adjustment to move the pedal up? I have a gsr master cylinder and the brakes that i had in there from a 99si had much more pedal. Any help would be great.
Old Feb 12, 2004 | 05:53 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: Problems with itr calipers on 92 hatch (timnparts)
you sure you didn't miss a connection somewhere and have one loose so air is getting in? make sure you didn't cross thread anything.
and you've bled all 4 corners? if you swapped the master cylinder there could be air still in one of the lines, especially a back one as it's got about 14 feet of line to progress through if it was a bubble at the front.
keep at it...
Old Feb 12, 2004 | 06:13 PM
DALE-EK4's Avatar
Default Re: Problems with itr calipers on 92 hatch (stackz)
i didnt swap the mc only the calipers and rotors in the front i have bled them at least 6 times i will try again i guess. i really dont think thats it though. thanks for the reply any other ideas
Old Feb 15, 2004 | 09:32 AM
DALE-EK4's Avatar
rebled lines and no better any other ideas? im thinkin about gettin an itr master and brake booster.
Old Feb 15, 2004 | 09:38 AM
Shawn C's Avatar
In The Garage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timnparts &raquo;</TD></TR><TR><TD CLASS="quote"> im thinkin about gettin an itr master and brake booster. </TD></TR></TABLE>
aren't they both 15/16"??
make sure that your master cylinder isn't leaking or anything (look up by the pedal inside the car)
Old Feb 15, 2004 | 09:41 AM
JDMlyfestyle's Avatar
what about the check valve on the brake vaccum i know if thats put in backwards u wont have breaks
Old Feb 15, 2004 | 10:32 AM
elwood's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 &raquo;</TD></TR><TR><TD CLASS="quote">aren't they both 15/16"??
no its a 1"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">what about the check valve on the brake vaccum i know if thats put in backwards u wont have breaks</TD></TR></TABLE>
I doubt that is it, it would actually make it harder to push
the pedal down, because the booster wont be working
with out it. Breaks still work fine, just really hard to
use them.
Old Feb 20, 2004 | 06:04 AM
DALE-EK4's Avatar
Default Re: Problems with itr calipers on 92 hatch (KiNg56)
4040
Old Feb 21, 2004 | 05:29 AM
saleensolution's Avatar
i put itr suspention on my girl friends car it had the same probiems, i ended up using a master cylinder out of a 92 si (but a 4 wheel disk non abs master will work) and a proportion valve out of a integra (non abs 94 +) that has the number 4030. i only found one in the local junkyard. then after that bleed them agan starting at the pass rear, then driver side rear, pass front, and last driver front.
Old Feb 21, 2004 | 05:38 AM
boostedcivicsir's Avatar
Mr. Badwrench
i have seen this before and dont laugh, make sure the calipers are on the correct side. if they arent, the bleeders will be at the bottom. not the top where the air needs to get out. i have seen this plenty of times. good luck.
Old Feb 21, 2004 | 07:30 AM
pro1342's Avatar
You need the master cylinder and booster......
Old Feb 26, 2004 | 06:16 PM
DALE-EK4's Avatar
Default Re: (pro1342)
i just ordered one i get it next week hope it works
ray257
Suspension & Brakes
Oct 7, 2010 09:11 AM
abusedhusband
Suspension & Brakes
May 30, 2007 10:28 AM
92eg6b16
13
Mar 10, 2007 04:30 PM
92eg6b16
Feb 5, 2007 08:04 PM
95civickid
Feb 1, 2005 11:02 PM
