How long will a T3/t4e 60 trim take to spool up around 16psi???
Old Feb 12, 2004 | 04:42 PM
Mr.DC2TurBo's Avatar
Default How long will a T3/t4e 60 trim take to spool up around 16psi???
I can't decide what to get. A garret t3/t4e 57 trim or 60 trim (a/r is .63). This will be on a LS (redline 6800) and I want to boost around 16psi (~300hp). Bottom is built but no sleeved. I want a turbo to not be soo laggy and to hit around full boost at 4300rpm. Which will be better and does the 57 trim and 60 trim make that big of a difference??
Old Feb 12, 2004 | 04:49 PM
b18b1hmtlove's Avatar
sounds like you should be getting the .48ar if you want full boost at that rpm
Old Feb 12, 2004 | 04:55 PM
Default Re: (b18b1hmtlove)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you should be getting the .48ar if you want full boost at that rpm</TD></TR></TABLE>
Ok, so wat rpm will I get full boost?
Old Feb 12, 2004 | 05:03 PM
4300-4800 at 16psi maybe....
.48a/r is made for the ls
Old Feb 12, 2004 | 05:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">4300-4800 at 16psi maybe....
.48a/r is made for the ls</TD></TR></TABLE>
ya but no power. . I wont hit 300 with 16psi and I dont want to boost even higher to get 300 (20psi).
Old Feb 12, 2004 | 05:26 PM
TurboJesse
Guest
Posts: n/a
Default Re: (Mr.DC2TurBo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">
Didnt' you have another thread where everyone tried to explain to you that it doesn't matter the boost it takes to reach 300whp?
Old Feb 12, 2004 | 05:41 PM
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
Didnt' you have another thread where everyone tried to explain to you that it doesn't matter the boost it takes to reach 300whp? </TD></TR></TABLE>
ya. my goal now is to hit low 300 around 16psi and then later on ill upgrade my 440cc to 550 and turn the boost up. t3/t4b wont be efficient soon so I might as well upgrade now. Just trying to figure wat turbo I should get now so later I can turn the boost up when I get more cash.
Old Feb 12, 2004 | 06:32 PM
shermanyang's Avatar
get the 57 trim. that's what i have and i get full boost at 4.3k. this trim is capable of doing 400+whp
.63 a/r .60 compressor .57 trim t3/t04e
Old Feb 12, 2004 | 06:41 PM
Default Re: (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">get the 57 trim. that's what i have and i get full boost at 4.3k. this trim is capable of doing 400+whp
.63 a/r .60 compressor .57 trim t3/t04e </TD></TR></TABLE>
Wont the 60 trim spool up faster?
Old Feb 12, 2004 | 06:43 PM
tegasaurus's Avatar
on my t3/to4e 60 i spooled 10psi around 4400 with a mild exhaust leak. so 16 psi would be there fully (given you don't have any exhaust leaks), at around 4750.
-ryan
oxSLEEPERxo
May 7, 2006 06:54 PM
Turbo_y8
Mar 3, 2006 11:10 PM
Turbo_y8
Feb 2, 2006 09:20 PM
blackpearlcivic
Jan 26, 2006 05:24 PM
2.2EL
Oct 6, 2004 04:09 PM
