sppon tie bar and jdm header
Old Feb 12, 2004 | 04:14 PM
darkjedi022's Avatar
Default sppon tie bar and jdm header
i haev the spoon lower front tie abr ...and i am putting my jdm header in next month...will this have any problems??....will it go over the header or under ????..pics would help too ...thanks ps also i did a search and could not find it ... do you guys have instructions on skunk2 intake manifold on how to put it in ....puics would help too ,thanks
Old Feb 12, 2004 | 05:11 PM
SOHC_MShue's Avatar
Default Re: sppon tie bar and jdm header (darkjedi022)
search...there is a thread right above this one on doing the skunk2 intake manifold on a gsr motor
Old Feb 12, 2004 | 05:56 PM
spoon92hatch's Avatar
yes, it'll work - had mine done - put removed the tie bar because it was way too slow.
Old Feb 12, 2004 | 06:03 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkjedi022 &raquo;</TD></TR><TR><TD CLASS="quote">i haev the spoon lower front tie abr ...and i am putting my jdm header in next month...will this have any problems??....will it go over the header or under ????..pics would help too ...thanks ps also i did a search and could not find it ... do you guys have instructions on skunk2 intake manifold on how to put it in ....puics would help too ,thanks </TD></TR></TABLE>
The tie bar should sit under the header, but there's shouldn't be any clearance problems.
Old Feb 12, 2004 | 06:08 PM
Default Re: sppon tie bar and jdm header (spoon92hatch)
if it works..then y is everyone telling me it will sit low...now i am thinking if the header sits low.....that means either my tie bar will have to go ..or it would be a tight fit/...right ???..u got pics .....and for the gsr motor..i read on it .....its no as descriptive detail telling me if i need extra stuff
Old Feb 12, 2004 | 06:22 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkjedi022 &raquo;</TD></TR><TR><TD CLASS="quote">if it works..then y is everyone telling me it will sit low...now i am thinking if the header sits low.....that means either my tie bar will have to go ..or it would be a tight fit/...right ???..u got pics .....and for the gsr motor..i read on it .....its no as descriptive detail telling me if i need extra stuff</TD></TR></TABLE>
Because if you look under your car, and see how low the header sits, add another 2 inches or so to that for the bar plus the gap between it, and the header, it hangs low. With a 2inch drop you'll probably hit it quite a bit.
You didn't mention what header you're adding? If by "JDM," you mean TypeR, then you'll have plenty of clearance with the header, but the lower bar will be lower and more apt to hit something.
Old Feb 14, 2004 | 09:22 PM
Default Re: sppon tie bar and jdm header (rodrez)
my tie bar already hits bumps....so does the header go above the tie bar or under
WhoisDan
Feb 8, 2005 11:33 AM
akhom
Oct 12, 2004 04:12 PM
itr98spec
Apr 2, 2003 09:57 PM
