sppon tie bar and jdm header
i haev the spoon lower front tie abr ...and i am putting my jdm header in next month...will this have any problems??....will it go over the header or under ????..pics would help too ...thanks ps also i did a search and could not find it ... do you guys have instructions on skunk2 intake manifold on how to put it in ....puics would help too ,thanks
Re: sppon tie bar and jdm header (darkjedi022)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkjedi022 »</TD></TR><TR><TD CLASS="quote">i haev the spoon lower front tie abr ...and i am putting my jdm header in next month...will this have any problems??....will it go over the header or under ????..pics would help too ...thanks ps also i did a search and could not find it ... do you guys have instructions on skunk2 intake manifold on how to put it in ....puics would help too ,thanks </TD></TR></TABLE>
The tie bar should sit under the header, but there's shouldn't be any clearance problems.
Re: sppon tie bar and jdm header (spoon92hatch)
if it works..then y is everyone telling me it will sit low...now i am thinking if the header sits low.....that means either my tie bar will have to go ..or it would be a tight fit/...right ???..u got pics .....and for the gsr motor..i read on it .....its no as descriptive detail telling me if i need extra stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkjedi022 »</TD></TR><TR><TD CLASS="quote">if it works..then y is everyone telling me it will sit low...now i am thinking if the header sits low.....that means either my tie bar will have to go ..or it would be a tight fit/...right ???..u got pics .....and for the gsr motor..i read on it .....its no as descriptive detail telling me if i need extra stuff</TD></TR></TABLE>
Because if you look under your car, and see how low the header sits, add another 2 inches or so to that for the bar plus the gap between it, and the header, it hangs low. With a 2inch drop you'll probably hit it quite a bit.
You didn't mention what header you're adding? If by "JDM," you mean TypeR, then you'll have plenty of clearance with the header, but the lower bar will be lower and more apt to hit something.
akhom
10-12-2004 04:12 PM
itr98spec
04-02-2003 09:57 PM
