What OEM swaybar options for EF9 Civic or CRX , (E.G other models)
Old Feb 12, 2004 | 04:09 PM
virginia_dude's Avatar
Default What OEM swaybar options for EF9 Civic or CRX , (E.G other models)
what other models swaybars bolt up to the EF8 EF9 chassis to provide a cheap rear swaybar option. That are better than the OEM Si Bars but far cheaper than aftermarket ones.
Old Feb 12, 2004 | 04:11 PM
^jefs0ng's Avatar
Banned
Only oem bar I've ever seen used is the Si one..
Old Feb 12, 2004 | 04:15 PM
Default Re: (#jefs0ng)
I think the integra bars fit from certain modles years but not sure which, Not sure if EG bars fit or not. Tried a search but found nothing. But remember threads on the subject.
Old May 7, 2004 | 09:54 AM
EGbeater's Avatar
Default Re: installing a '88-91 CRX Si OEM rear sway bar on a '89 EF hatch standard
I can see that the mounting bracket holes are there, but there is no nut welded to the inside of the unibody.
Can I just drill upwards and put a nut on the other side (ie the inside of the car?)
Will the bolt holes line up with a flat section of the interior?
How do people do this; I'm sure I'm not the first person to want to install a CRX Si factory rear bar on a EF standard . . .
BTW, I know I'll have to drill holes in the LCA's to mount the endlinks, or replace the LCA's with CRX Si or Civic Si parts.
Old May 7, 2004 | 10:17 AM
johnjw's Avatar
Default Re: installing a '88-91 CRX Si OEM rear sway bar on a '89 EF hatch standard (CRXMR2SM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXMR2SM2 &raquo;</TD></TR><TR><TD CLASS="quote">I can see that the mounting bracket holes are there, but there is no nut welded to the inside of the unibody.
BTW, I know I'll have to drill holes in the LCA's to mount the endlinks, or replace the LCA's with CRX Si or Civic Si parts.</TD></TR></TABLE>
yea what I did was I used a hole saw and made a 3 inch hole and put a nut down in there so it would bolt to something
Old May 7, 2004 | 12:06 PM
EGbeater's Avatar
Default Re: installing a '88-91 CRX Si OEM rear sway bar on a '89 EF hatch standard (johnjw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnjw &raquo;</TD></TR><TR><TD CLASS="quote">
yea what I did was I used a hole saw and made a 3 inch hole and put a nut down in there so it would bolt to something</TD></TR></TABLE>
Oh crap, so the first layer you drill through from the bottom isn't the inside of the car???
Any chance you have (or can take) a picture of it? Is your car a 4th gen Civic hatch?
That would be great if you could. But, the one 3" diameter hole is big enough to get to both nuts to secure the bracket right? And is the 3" hole covered by the OEM interior panel or not?
Old May 7, 2004 | 12:16 PM
chadmasterc's Avatar
My 91 dx came with threaded holes, I guess I got lucky.
Old May 7, 2004 | 12:52 PM
EGbeater's Avatar
Default Re: installing a '88-91 CRX Si OEM rear sway bar on a '89 EF hatch standard (chadmasterc)
I think DX chassis EF hatches are different than basic (ie no trim level at all).
I can't think that this saved Honda any money, making two different unibodies, one with nuts welded in and one without. WTF were they thinking???
Old May 7, 2004 | 03:41 PM
deftones0817's Avatar
92 - 95 eg sway bars do not work
94 + integra sway bars do not work.
I tried both for those years so i know for a fact. They hit the frame of the car
DEF
Old May 7, 2004 | 05:17 PM
auto-x's Avatar
New User
Default Re: installing a '88-91 CRX Si OEM rear sway bar on a '89 EF hatch standard (deftones0817)
90-93 integra will work. how do i know? i installed them on my 88 crx. use the tow bar holes for the rear.
Old May 7, 2004 | 06:37 PM
Default Re: installing a '88-91 CRX Si OEM rear sway bar on a '89 EF hatch standard (auto-x)
I end3ed up with an Si Sway bar I got for real cheap, took A little creativity but it works awesum and was cheap. Far better than no sway bar in back
Old May 7, 2004 | 07:26 PM
B1TEM3's Avatar
Default Re: installing a '88-91 CRX Si OEM rear sway bar on a '89 EF hatch standard (virginia_dude)
QUOTE:BTW, I know I'll have to drill holes in the LCA's to mount the endlinks, or replace the LCA's with CRX Si or Civic Si parts.
I do not think drilling LCA would be best idea, getting the Si LCA would be.
I just need to spot weld the L bracket when I install my exhaust (i want to make sure it clear and wont hit each other).
right now, i scrape all the Noise dreadener from the sway bar, then paint it.
Old May 7, 2004 | 08:21 PM
Default Re: installing a '88-91 CRX Si OEM rear sway bar on a '89 EF hatch standard (B1TEM3)
good info guys keep it up. Im going to try 90 - 93 integra sway bars see how that works.
DEF
Old May 7, 2004 | 08:26 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
why would you not want to get an aftermarket antisway bar?
there are rear bars available for less than $150 and a stock SI and DX front bar bolts on with the LCA's that have an eye for it.
or look for used ones, i picked up my ST pair for $150.
by the time you modify the car, mounting points and the bar you will spend the same amount.
BTW, ST rear endlinks mount to the lower mounting point of the dampers. so there is no need for SI LCAs.
stan
Old May 7, 2004 | 08:28 PM
Boosted Chemist's Avatar
Default Re: installing a '88-91 CRX Si OEM rear sway bar on a '89 EF hatch standard (Stan D)
ST
n1div
Mar 26, 2007 06:25 AM
n1div
Mar 26, 2007 06:24 AM
sly mantis
Nov 19, 2006 05:39 PM
ArinX
Suspension & Brakes
Sep 12, 2005 09:37 PM
808State
Feb 11, 2005 05:38 PM
