Eagle Haters and Pauter lovers info inside
Old Feb 12, 2004 | 02:37 PM
PM-Performance's Avatar
Default Eagle Haters and Pauter lovers info inside
Well since we hear all this info that Eagles are bad becuase of the Rod bolts.I was looking thru the new Dragsport and i dont know if this is a missprint or what but the Pauters are listed with 5/16 bolts too. is this a missprint?
Old Feb 12, 2004 | 02:53 PM
Cruiser G's Avatar
Default Re: Eagle Haters and Pauter lovers info inside (itr206)
I remember earl saying in a post that the bolt size is the same, but the ones in the Pauters are a lot stronger.
Edit: here it is:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">They do come with 5/16" bolt but you must understand that this bolt has MUCH more tensle strength than the 3/8" bolt in Eagle Rods or Crower rods. This is an extremely expensive bolt and was incorporated in that rod in order to save weight. Most B16 Pauter rods wind up in Baja class cars that must run a B16 motor. Those guys require a bad *** rod that will take a beating and live and they all use Pauters.
You must remember there are $2 bolts and there are $20 BOLTS</TD></TR></TABLE>
Old Feb 12, 2004 | 03:01 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">Well since we hear all this info that Eagles are bad becuase of the Rod bolts.I was looking thru the new Dragsport and i dont know if this is a missprint or what but the Pauters are listed with 5/16 bolts too. is this a missprint?</TD></TR></TABLE>
there are stronger bolts available for ealge rods and these blots can be torqued higher.
Old Feb 12, 2004 | 03:06 PM
Default Re: Eagle Haters and Pauter lovers info inside (vtec.dc2)
the tq requirements ar the same according tothat article. matter of fact some of the 3/8 bolts are the same requiements too. So ARP bolts are cheap?. the whole mess from my searches everyone was saying the rod bolts were junk because the size and only needing 28ft lbs.
Old Feb 12, 2004 | 03:17 PM
vtec.dc2's Avatar
maybe they are reffering to bolts where threads need to be resized.. i'm talking about custom age 625 that should be the same size but can be torqued higher.. you will need to resize rods but bolts should be the same.. its an upgrade available for 100 dollars when you purchase eagle rods.
Old Feb 12, 2004 | 05:45 PM
Joseph Davis's Avatar
Eagles are Carillo knock offs. The design is wonderful, the rod bolt as already pointed out is inadequate above certain already established power levels.
Old Feb 12, 2004 | 05:46 PM
earl's Avatar
I've seen 5/16" bolts with 25lb torque spec and 5/16 bolts at 45lb spec
Old Feb 12, 2004 | 10:48 PM
Kwuaymaikrup's Avatar
Default Re: Eagle Haters and Pauter lovers info inside (earl)
I actually have my Pauter work order right here in front of me and it says 50ft/lbs for the torque spec.
-Ryan
Old Feb 13, 2004 | 01:44 AM
SiR Kid's Avatar
New User
Default Re: Eagle Haters and Pauter lovers info inside (Kwuaymaikrup)
You guys just don't get that it's not the torque on the nut that makes a rod hold together, do you?
Old Feb 13, 2004 | 03:18 AM
Default Re: Eagle Haters and Pauter lovers info inside (SiR Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">You guys just don't get that it's not the torque on the nut that makes a rod hold together, do you?</TD></TR></TABLE>
from all the past arguements it seems so .
like i said i saw the article on the diff rods and figured it was good info , i can count numerous posts where a ton of people on here are like ohhhh dont get em , they only have 5/16 bolts, and only 28ft lbs . why would you run a rod that only needs 28ft lbs . lol.
Old Feb 13, 2004 | 04:41 AM
Adriano's Avatar
My eagle rods came with arp bolts. Are they good are bad??
Old Feb 13, 2004 | 04:44 AM
Default Re: Eagle Haters and Pauter lovers info inside (brryder)
again from the above arguements it sounds like they are bad .
Old Feb 13, 2004 | 04:55 AM
yellowturbo's Avatar
I dont believe that Eagle rods are bad under 400 whp ... you are talking about thing for a really hardcore engine IMO...
Old Feb 13, 2004 | 06:28 AM
earl's Avatar
The more torque you can apply to a bolt without it stretching out of control, the higher the quality of the bolt.
Old Feb 13, 2004 | 06:35 AM
like i said unless its a missprint, Dragsport showed most of the bolts being tq'ed to the same or right around the same levels on the Pauter rods, and the new Carillo;s i beleive too and i believe another one .
Old Feb 13, 2004 | 07:13 AM
Dyno Queen's Avatar
Pauter is badass!! Got some for my GSR
Old Feb 13, 2004 | 08:05 AM
B18c1turboedEK's Avatar
Default Re: Eagle Haters and Pauter lovers info inside (Dyno Queen)
Well i know of 2 cars personally running over 580 HP running eagle rods!!! I wanna know how many people actually blew motors becasue of the rods???
Old Feb 13, 2004 | 04:16 PM
93LSivic's Avatar
Default Re: Eagle Haters and Pauter lovers info inside (Koticcivic4u)
FWIW, I spoke with a tech from Eagle just the other day. ALL of their VTEC B series rods will now come standard with 3/8" ARP fasteners. They say its due to popular demand based on feedback from customers...weird, they always had it as an option so couldnt the customer just buy the "optional" rod? Kinda makes me think.
Take this as you like. I never had a problem with any of the Eagles Ive built motors with using both the 3/8 and the 5/16.
Old Feb 13, 2004 | 05:21 PM
MiraiZ's Avatar
Default Re: Eagle Haters and Pauter lovers info inside (93LSivic)
been boosting 300+whp 240tq, for a year w/ bog standard eagles...no probs...
Old Feb 14, 2004 | 12:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">The more torque you can apply to a bolt without it stretching out of control, the higher the quality of the bolt.</TD></TR></TABLE>
Exactly the point I was making. I understand that the big torque #'s don't always mean better holding but it speaks margins for the bolt quality.
-Ryan
Old Feb 14, 2004 | 01:09 AM
SiR Kid's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">
-Ryan</TD></TR></TABLE>
If it's the BOLT'S fault, and the BOLT is weak, then why aren't you naysayers bashing ARP for putting out a weaksauce rodbolt in the first place?!!?
Old Feb 14, 2004 | 03:20 AM
Cyber ITR's Avatar
itr206 arent you making big power with stock eagle rods ???
to be honest im scared to use my eagle rods , they are the reason i havent finished rebuilding my engine yet ....
Old Feb 14, 2004 | 07:13 AM
Naterror's Avatar
Default Re: Eagle Haters and Pauter lovers info inside (Day Walker)
I know a guy around here thats making almost 600hp on eagle rods daily driven and has no problem with them.
Old Feb 14, 2004 | 07:24 AM
Boostfed's Avatar
New User
My old set up had Eagle rods 500whp 25psi, no problems with the rods at all BUT when I did the new set up I just spent extra money on the bolts to be certain I had no problems, I bought Pauter rods. Now keep in mind the Pauter B16A rods are 5/16 bolt while the GSR are 3/8 bolts. See my old post here
https://honda-tech.com/zerothread?id=529188
Old Feb 14, 2004 | 07:32 AM
Dr Pooface's Avatar
Default Re: (Boostfed)
I know a guy who makes 400+ hp on eagles daily driven/circut track.
Has ANYONE heard of the eagles+3/8 ARPs failing?
