Emissions help!!! Can't Pass!
Here's the situation: I have a 99 si with toda spec b cams and internals, mugen ecu, wired up obd1, no cat and fail emissions. I turned my fuel way down on my vafc and ran with a SOHC civic obd1 ecu (p28) and passed cruising but failed idle for hydrocarbon. passing is 220 and i put out 309. any ideas on what to do with out paying to have a cat welding on? ....Im runnin a straight pipe right now.
go to napa and get a cat...spend the 20 bucks to have 2 flanges welded to each end of it and bolt it on..then pass emissions ..cats from napa are 80-100 bucks depending on size
i had the same problem, to pass low speed i turned up my idle to like 1000 rpms and went to autozone and bought this **** "berrymans pass emissions" and that helped burn off the hydrocarbons at idle. when i first did the test i was at 318 then with these to things i got it down to 201. i think turning up the idle helped out the most
Good luck and that should work for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwil6666 »</TD></TR><TR><TD CLASS="quote">your going to need a cat to pass and make sure you get it good and hot before the test.
keith </TD></TR></TABLE>
i didnt have a cat and i passed
If I was inspecting your car you'd never pass - you are lucky and should be grateful they even ran it on the machine, what with OBD-1 and no cat.
Get a cat and you'll be almost guaranteed to pass. My 2000 Si puts out 0 emissions in both tests.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip Driver »</TD></TR><TR><TD CLASS="quote">go to napa and get a cat...spend the 20 bucks to have 2 flanges welded to each end of it and bolt it on..then pass emissions ..cats from napa are 80-100 bucks depending on size</TD></TR></TABLE>
That's funny you suggested this because I just decided I wanted it done and didn't wanna fus with anything. I went to Napa and picked up a universal cat for 93 after taxes and am having it welded on mon. by my friend's bro. I came home and checked this post to see the replies and that's what i did. I'll let you know how the results are.. I dont think i'll have a problem
Rywire
Jan 17, 2005 09:58 PM
lelopez
17
Aug 17, 2003 05:40 PM
