CR-V bottom end in Integra...
Old Oct 9, 2001 | 11:26 AM
d8168055's Avatar
Default CR-V bottom end in Integra...
is this possible? to put the bottom end of a CR-V in an integra? I saw it in Import Tuner, i think... i know the CR-V is civic-based... so i guess it will fit... if so, this is better than an LS/VTEC conversion... huh? Has anyone else heard of this or done this? let me know the results...
Old Oct 9, 2001 | 11:32 AM
Black SVT's Avatar
Default Re: CR-V bottom end in Integra... (d8168055)
Import review has a few 11 sec n/a Civics with this set up.It is a b20.Just like all the b series stuff you can mix and match.To answer your question yes,it is kinda like an ls/vtec.I am not sure how much better it is but they make a lot of torque.
Old Oct 9, 2001 | 11:33 AM
ezark's Avatar
Yup, talk about torque :] it is better than ls/vtec- .2mm bore more i believe - will make you a 2.0 . you got the money, get it done!! if you are interested, you should talk to http://www.prospeed-performance.com/
Old Oct 9, 2001 | 11:37 AM
MackSpeed-616's Avatar
keep in mind you will also need some pricey head work in order to get enough flow to make the b20/vtec work properly .. as well as "spot facing" or matching the underside of the head to the larger bore.
b18c bore is 81mm
b20 bore is 84mm
vtecvoodoo's Avatar
Future Texas Boy
Default Re: CR-V bottom end in Integra... (krazE)
Import Tuner had an s2000 w/ a b20 too! If they said you can do it then it must ne true haha
Old Oct 9, 2001 | 11:44 AM
sgT's Avatar
sgT
Default Re: CR-V bottom end in Integra... (vtecvoodoo)
s2000 with a b20? hahahahahaha
thats some funny ****. i wonder what idiot would try to do that.
Old Oct 9, 2001 | 11:47 AM
B18CXr's Avatar
Default Re: CR-V bottom end in Integra... (sgT)
I think that shop and the word "idiot" go handNhand.
Old Oct 9, 2001 | 11:48 AM
ezark's Avatar
ROFL!!~
Old Oct 9, 2001 | 12:00 PM
vtecvoodoo's Avatar
Future Texas Boy
bad *** tech editors, huh? haha
Dasfinc
66
Jun 19, 2013 02:38 PM
Nguyenv25
Nov 8, 2005 11:41 AM
BigPlansNoMoney
Oct 22, 2004 01:17 PM
accord5speed
Jul 25, 2002 09:43 PM
