what aftermarket clutch/flywheel do you guys use on your R
Old Feb 12, 2004 | 07:14 AM
danny98r's Avatar
Default what aftermarket clutch/flywheel do you guys use on your R
i have a 98 type r with i/e/h and also got a clutchmasters stage 3 clutch with their flywheel. i just want to know which setup you guys use and if u guys experience any clutch chatter?
Old Feb 12, 2004 | 08:21 AM
Kendall's Avatar
I've always used the stock one. Never had a problem.
Old Feb 12, 2004 | 08:30 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (Kendall)
Clutchmasters Stage 2 currently, with no problems at all, and ACT HD before, which may or may not have had a rather large problem, though not at all with chatter.
Old Feb 12, 2004 | 09:11 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: (sscguy)
Toda/Toda
Old Feb 12, 2004 | 09:19 AM
Footwork's Avatar
Default Re: what aftermarket clutch/flywheel do you guys use on your R (danny98r)
After stock I went with JUN/Win-Sport 3 puck w/JUN ultralight flywheel, now I have the SP 6 puck clutch and the same flywheel.
(The real SP... http://www.sp-power.com/catalog/)
Old Feb 12, 2004 | 09:22 AM
mstewar's Avatar
ACT HD/SS and a Fidanza Flywheel.. Pretty nice!
Old Feb 12, 2004 | 09:30 AM
thk's Avatar
thk
Members Only
Default Re: (RealTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Toda/Toda </TD></TR></TABLE>
Toda/OEM right now but I'll probably move up to the Toda clutch if I feel like splurging when the time comes. If I don't feel like splurging, I'm getting an OEM again.
Old Feb 12, 2004 | 09:38 AM
jonas's Avatar
toda clutch, toda flywheel
Old Feb 12, 2004 | 09:44 AM
Suspetise...
Default Re: (jonas)
You Toda/Toda guys, how much did that combination cost?
Old Feb 12, 2004 | 09:46 AM
RTW DC2R's Avatar
Ill be buying a new clutch soon, I havent decided which one yet. I have the CM flywheel. My current set up has a lot of chatter, but its a ceramic/metalic disc and its garbage. I cant afford the bling so Ill probably stick with an ACT clutch or something.
Old Feb 12, 2004 | 10:29 AM
Chris93Si's Avatar
Exedy Organic clutch and Toda Flywheel, no complaints
Old Feb 12, 2004 | 11:02 AM
slackeR1366's Avatar
Same as you... CM Stage 3 and flywheel...no chatter
Old Feb 12, 2004 | 11:07 AM
Flux's Avatar
Default Re: what aftermarket clutch/flywheel do you guys use on your R (R1366)
I am installing the TODA clutch and flywheel next week sometime...
Old Feb 12, 2004 | 11:42 AM
Miracle_X_Bar's Avatar
Default Re: what aftermarket clutch/flywheel do you guys use on your R (Flux)
clutchmasters 4 puck and a no-name flywheel...4th gear neck breaker!!!
Old Feb 12, 2004 | 11:50 AM
splitime's Avatar
Default Re: what aftermarket clutch/flywheel do you guys use on your R (Miracle_X_Bar)
ACT prolite flywheel and Action 1MS (6puck sprung).
Nice revs with the flywheel, nice grab from the clutch which has an almost OEM feel with a higher engagement point on the pedal. I find I can shift a little quicker, its nice.
Old Feb 12, 2004 | 02:54 PM
Champ R's Avatar
To those with the Toda, how does the clutch feel/grab compared to stock?
Old Feb 12, 2004 | 02:56 PM
vtec.dc2's Avatar
clutch disk = stock
release bearing = stock
pressure plate = 1800lbs
flywheel = 8.5lbs
clutch noise or chatter = 0
Old Feb 12, 2004 | 02:57 PM
NSX Bob's Avatar
New User
Default Re: what aftermarket clutch/flywheel do you guys use on your R (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">ACT HD/SS and a Fidanza Flywheel.. Pretty nice!</TD></TR></TABLE>
Same here, I like the setup so far (10k miles).
Old Feb 13, 2004 | 05:52 AM
SergEK's Avatar
ACT HD PP with Copper lined ACT street disc with Toda Fly
Revs great, grabs hard....pedal feel is just right...not too squishy, not rock hard.
I will try the Toda clutch on my next replacement.
Old Feb 13, 2004 | 05:53 AM
Misfit's Avatar
Default Re: what aftermarket clutch/flywheel do you guys use on your R (Chris93Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris93Si &raquo;</TD></TR><TR><TD CLASS="quote">Exedy Organic clutch and Toda Flywheel, no complaints </TD></TR></TABLE> same here
Old Feb 13, 2004 | 07:40 AM
RPM's Avatar
RPM
ATS Carbon Clutch(single carbon disk), ATS Pressure Plate, and ATS Carbon Steel Flywheel.
jdmB18CT-R
Feb 10, 2006 11:28 AM
AamirCWITR
Oct 28, 2002 08:06 PM
cyberx
22
Oct 21, 2002 06:17 PM
BoostedGSRBubble
Sep 15, 2002 09:50 AM
nsx-Animal
Aug 13, 2002 05:21 PM
