obd0-obd1 conversion
does anyone in the bay area 510 kno where i can get my obd0-obd1 conversion done for cheap..free...anyhing? i have all the parts needed and i need someone to help me do it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dgonzals »</TD></TR><TR><TD CLASS="quote">how much money u got????labor cost you know...</TD></TR></TABLE>
not alot of it at the moment
what kind of motor do you have right now? b16? d16? d15? are you already wired up for mpfi? i'm doing the conversion right now with blown90hatch's conversion harness...really easy, but i just didn't have time...you say you have all the parts but this is what i had and what i needed to get to go obd1
started with:
obd0 b16a with a converted stock 90 si harness to match the b16
parts i bought:
blown90hatch's obd0-obd1 conversion harness
4-wire o2 sensor
stock obd1 b16 exhaust manifold (it has ONE hole for the oxygen sensor instead of the stock obd0, which had 2 oxygen sensors)
92-93 gsr distributor
stock p30 (94-95 del sol b16) ecu
16 gage wire to hook up o2 sensor
a whole bunch of wiring stuff to cut and reconnect wires
haven't started my car yet, but hopefully that baby will fire right up
started with:
parts i bought:
4-wire o2 sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLICC916 »</TD></TR><TR><TD CLASS="quote">what kind of motor do you have right now? b16? d16? d15? are you already wired up for mpfi? i'm doing the conversion right now with blown90hatch's conversion harness...really easy, but i just didn't have time...you say you have all the parts but this is what i had and what i needed to get to go obd1
started with:
parts i bought:
4-wire o2 sensor
haven't started my car yet, but hopefully that baby will fire right up</TD></TR></TABLE>
i have the boomslang obd0-obd1 wireharness
95 civic dizzy it was a dx but rewired for si
p28 ecu
4 wire 02 sensor but the grey clip is cracked need hardwire
and the motor is alredy converted to mpfi and its a 95 sohc d16z6 runnin on obd0 injectors
i want to do this because im hopin after its converted to obd1 it will run stronger and it will pass smog =/ the most touble im going to have even if its a easy job is to hardwire the o2 sensor and i need the vtec silnoid line too thats it
started with:
parts i bought:
4-wire o2 sensor
p28 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RsINtEg- »</TD></TR><TR><TD CLASS="quote">
I am glad he offers tech support.
