oil drain does it have to be S.S.?
Old Feb 12, 2004 | 05:59 AM
yusoslo's Avatar
Default oil drain does it have to be S.S.?
my turbo kit is ready to install but it came with the high temp rubber hose. Everyone has stainless steel lines, are they really neccesary.
I already have the flanges on the turbo and a matching one to be welded to the oil pan to clamp down this hose.
do i really need the 75 drain kit?
Old Feb 12, 2004 | 06:14 AM
ITSTOCK's Avatar
Default Re: oil drain does it have to be S.S.? (yusoslo)
You dont NEED the SS lines, you can use the rubber hoses. The SS lines are just alot stronger then the rubber, the rubber lines can obviously be cut easier.
Old Feb 12, 2004 | 06:29 AM
Ri5e's Avatar
Default Re: oil drain does it have to be S.S.? (ITSTOCK)
I run regular high temp rubber hose. You should use S.S. if you're running the hoses close to the down pipe
Old Feb 12, 2004 | 06:55 AM
DaveF's Avatar
Default Re: oil drain does it have to be S.S.? (CRV Monster)
you wont have leaks with the SS line...but with the high temp ruber bs, that clamps onto the pipe....you will get leaks there.
Old Feb 12, 2004 | 07:16 AM
quikB18B's Avatar
Default Re: oil drain does it have to be S.S.? (2.2Lcivic)
Some people run the rubber, but it's not worth it IMO. Think about how bad an oil leak can be....... Now compare the cost of Stainless Oil lines to a motor
It's your call, your car, but I wouldn't feel comftorable doing it. If it's the $ your worried about my suggestion is find somewhere else in your setup to save the $75.
Better safe than sorry.
GPNY
Welding / Fabrication
19
Jul 11, 2009 10:53 PM
K i l l a B e e.
Sep 30, 2007 03:41 PM
TurboCiviCX
Mar 21, 2006 02:33 AM
FlyZlow
Jun 7, 2005 05:45 PM
PA MATT
Aug 5, 2004 09:00 AM
