problems with zc swap?
Old Feb 11, 2004 | 08:18 PM
4potnick's Avatar
Default problems with zc swap?
I just put a zc motor in a 88hf shell i bought. I am having problems getting it started. I have fuel, spark, and compression. I am getting a cel for codes 6, 10, 13. Can anyone shed some light on to why it won't start. When I first turn it over it sounds like it wants to start but then just goes rrnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn and nothing.
4potnick's Avatar
Default Re: problems with zc swap? (4potnick)
Did I mention that zc sucks for search.
Old Feb 11, 2004 | 08:56 PM
CRXRageD's Avatar
search on google. You will find more that way than HT.
Old Feb 12, 2004 | 06:07 AM
4potnick's Avatar
Default Re: problems with zc swap? (CRXRageD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXRageD &raquo;</TD></TR><TR><TD CLASS="quote">search on google. You will find more that way than HT. </TD></TR></TABLE>Isn't H-T the biggest honda related site? Anyone else?
Old Feb 12, 2004 | 07:07 AM
jlicrx's Avatar
sounds like a wiring problem - what engine harness is on it? which ECU?
Old Feb 12, 2004 | 07:09 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
yes it is the biggest honda related site...but when u search you have to have atleast 3 characters.....on google u can use as many as u want....
Old Feb 12, 2004 | 07:53 AM
crxgator's Avatar
Default Re: (dgonzals)
code 6- coolant temp. sensor. check the plug underneath the distributor and make sure its connected or if the wires are cut. (if i remember right, the car wont start without this connected)
code 10- Intake Air Temp. see if the sensor on the driver side of the intake manifold, its white and held on by 2 screws, if that is connected
code 13- Atomospheric Pressure. thats a bitch and you have to do a bunch of voltage messuring at the ecu, try a different ecu for that one and see if it clears...
Old Feb 12, 2004 | 08:22 AM
JonGP4's Avatar
hrmm it should start, if its been sitting for awhile which most like it has try this.. disconect all the injectors, start cranking it, when it sounds like its going to start, and has enoughc ompression, then have someone clip them all back on while ur still cranking,
whats happening is the engine is getting flooded with to much fuel and burning off all the oil, and its not getting enough compression.
anyways try that.. as for the codes, check all ur grounds
Old Feb 14, 2004 | 07:22 AM
4potnick's Avatar
Default Re: (JonGP4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 &raquo;</TD></TR><TR><TD CLASS="quote">hrmm it should start, if its been sitting for awhile which most like it has try this.. disconect all the injectors, start cranking it, when it sounds like its going to start, and has enoughc ompression, then have someone clip them all back on while ur still cranking,
anyways try that.. as for the codes, check all ur grounds</TD></TR></TABLE> I will give this a try. I did a compression test and all cylinders are 192.
Old Feb 14, 2004 | 11:27 AM
4potnick's Avatar
Default Re: (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">code 6- coolant temp. sensor. check the plug underneath the distributor and make sure its connected or if the wires are cut. (if i remember right, the car wont start without this connected)
code 13- Atomospheric Pressure. thats a bitch and you have to do a bunch of voltage messuring at the ecu, try a different ecu for that one and see if it clears...</TD></TR></TABLE>Does anyone know how to check voltage to coolant temp sensor? I have a multimeter. I just don't know what I am looking for voltage wise? Do you know the colors to wires going to the intake air sensor. I want to make sure I didn't mix up any wires. I am going to swap out the ecu out of my obd0 integra tomorrow to see if it helps.
Old Feb 15, 2004 | 12:21 AM
4potnick's Avatar
Default Re: (4potnick)
ttt
Old Feb 15, 2004 | 05:50 AM
crxgator's Avatar
code 10
Old Feb 15, 2004 | 08:04 AM
4potnick's Avatar
Thanks! hopefully I'll get the car running today.,
Old Feb 15, 2004 | 08:16 AM
4potnick's Avatar
Can you run these tests even though the car does not run?
Old Feb 15, 2004 | 08:39 AM
crxgator's Avatar
yeah...
Old Feb 15, 2004 | 09:37 AM
4potnick's Avatar
ok... Well come to find out that the codes were from me swapping plugs only to find out that wasn't the problem. I switched thwm back but didn't properly reset the ecu . Anyways, car turns over but doesn't start. It blows out a bunch of dark smoke and smells like gas.. anyone with some new ideas.
Old Feb 15, 2004 | 09:38 AM
4potnick's Avatar
ok... Well come to find out that the codes were from me swapping plugs only to find out that wasn't the problem. I switched thwm back but didn't properly reset the ecu . Anyways, car turns over but doesn't start. It blows out a bunch of dark smoke and smells like gas.. anyone with some new ideas. crxgator thats for the help.
Old Feb 15, 2004 | 09:39 AM
4potnick's Avatar
I will pay someone in central florida that want to help me troubleshoot and get the car running.
Old Feb 15, 2004 | 09:48 AM
crxgator's Avatar
talk to John at RPI racing in orlando, he works mainly on crx's...
Old Feb 15, 2004 | 09:57 AM
4potnick's Avatar
Do you have any info for them? I don't reallyu want to tow it somewhere if I don't have to, I think I am running out of options....When I swapped the motor in my integra things went so much smoother.
Old Feb 15, 2004 | 12:31 PM
4potnick's Avatar
anyways try that.. as for the codes, check all ur grounds</TD></TR></TABLE>Tried this and it backfired out of the intake once or twice and that was it&gt;
Old Feb 15, 2004 | 07:52 PM
civais's Avatar
Just curious...what ecu are you using? Did you check your TPS sensor?
Good luck..I feel your pain!
Old Feb 15, 2004 | 08:42 PM
ThefirstPACT's Avatar
Default Re: (civais)
check your plugs they could be fouled by all the fuel from cranking the damn thing over to much! I had that problem. Also make sure firing order is correct. Be cause you could be getting spark but not in the right order!
Old Feb 17, 2004 | 10:38 AM
4potnick's Avatar
Default Re: (ThefirstPACT)
found out I mixed up 2 white wires for dizzy. problem solved.
Old Feb 17, 2004 | 12:34 PM
1point5CRX's Avatar
nice to hear. my zc should of been runnning a week ago but we bent the valves on startup- i didnt do the timing but the guy i got it from didnt make me pay him anything for it, free ZC. me and boostedb20vtec will have it up and running friday
illistEF
16
Nov 8, 2006 09:55 AM
racingcrx
Apr 9, 2006 09:59 AM
JDMEJCIVIC_CTR
Feb 13, 2005 01:57 PM
efracer
Aug 30, 2004 08:52 PM
sickciv
May 13, 2003 08:04 PM
