B18C swap into a CRX
Old Feb 11, 2004 | 06:54 PM
donpeters's Avatar
Default B18C swap into a CRX
What is the difficulty level of swapping a '96 GSR B18C engine into an 88-91 CRX? I would love to do this swap, as I have both the car and the engine sitting in my garage.
I am looking for as much information as possible and could use any input possible. I have been searching and found some answers, but nothing that I was really looking for. So far, I have learned that the wiring may be a little tricking and take some work and the swap will require a mount kit.
The mount kit shouldn't be a problem, but the wiring may be and if anyone could help me along with this or point me in the right direction that would be great.
Old Feb 11, 2004 | 07:17 PM
donpeters's Avatar
Default Re: B18C swap into a CRX (donnie4p)
Also, how will the tranny hook up? Could I use the GSR tranny in the CRX? If not, what would need to be done?
Old Feb 11, 2004 | 07:43 PM
fffrog's Avatar
get the hasport mount kit with the cable to hydro tranny conversion. you need axles, shift linkage. i think you can get a conversion harness for the wiring.
Old Feb 12, 2004 | 05:43 AM
donpeters's Avatar
Thanks, any more information would be great.
Old Feb 12, 2004 | 07:09 AM
donpeters's Avatar
Bump.
Old Feb 12, 2004 | 09:17 PM
hatchlessrex's Avatar
the swap is easy, if you have the tools for the swap ive done multiple b series swaps, you will need the mounts from hasport and the rear tranny mount from an integra. you can use a front mount if you have the money to get stuff welded and moved. but its fine with out it. and wiring depends on weither you have a dx hf or si. if its a dx then you have to convert to multi port from duel port. and if its an hf you need knuckles from an si.
Old Feb 12, 2004 | 09:26 PM
Fobtions's Avatar
Default Re: (hatchlessrex)
wiring is simple. just use your old engine harness off the sohc. add the knock sensor and vtec wires. Than u can either run a pr3/pwo obd0 ecu or u can run a obd 1 jumper and run the GSR ecu or p28
krazyblurtzcrx
17
Jan 31, 2007 11:05 AM
jdm_eg94_cincy
Apr 23, 2006 04:18 AM
hapa
Jul 12, 2004 10:30 AM
jonnyc
Dec 20, 2001 01:46 PM
