bad throwout bearing?
Old Feb 11, 2004 | 06:15 PM
civicmark's Avatar
Default bad throwout bearing?
When i have the car in neutral and i dont have my foot on the clutch, something in my tranny makes a really lound spinning noise. When i push in the clutch it stops, but as soon as i release it, the noise comes back. A friend of mine thought it might be the throwout bearing? Should i replace it, or go ahead and do the clutch too? Money is a little tight, but if it needs to be done, i can do both, but the clutch feels fine. It's on my eg
Old Feb 11, 2004 | 06:16 PM
infinatenexus's Avatar
1. its most likely your throw out bearing
2. you might as well replace everything since you already have it apart
Old Feb 11, 2004 | 06:25 PM
93civicEX's Avatar
I think its your Input shaft bearing, Its commen for them to go bad.
Old Feb 11, 2004 | 06:29 PM
lowblazin's Avatar
have you changed your tranny fluid at all. this happened to friend of mine. his tranny went out and when he got it fixed he was told it needed oil.
Old Feb 11, 2004 | 06:34 PM
civicmark's Avatar
Default Re: (lowblazin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowblazin &raquo;</TD></TR><TR><TD CLASS="quote">have you changed your tranny fluid at all. this happened to friend of mine. his tranny went out and when he got it fixed he was told it needed oil.</TD></TR></TABLE>
no, i think i'll give that a try before i open up the tranny, but i think i'm going to have to. This is a pretty loud noise...
Old Feb 11, 2004 | 06:37 PM
99blackcivicSi's Avatar
Default Re: (civicmark)
If your just barely on the clutch it is yoru T/O bearing not your imput shaft bearing and not your pilot bearing.
Old Feb 11, 2004 | 06:46 PM
nY's FiNeSt's Avatar
Default Re: (99blackcivicSi)
i have the same problem and was told that it's the input shaft bearing...
Old Feb 11, 2004 | 06:50 PM
civicmark's Avatar
The noise is there when it's in nuetral, and i don't have my foot on the clutch. when i press it to the floor the noise goes away.
Old Feb 11, 2004 | 07:11 PM
carsaregood's Avatar
its probably your input shaft bearing.
someone please correct me if i'm wrong but -
when you put the clutch pedal in (disengage it), and the car is not moving, the input shaft stops turning. with the clutch pedal out (engaged), the input shaft is connected to the motor, and starts turning again.
try getting the car rolling, put it in neutral, and step on the clutch pedal. the noise should still be there because the wheels are moving the tranny, if its the input shaft bearing, or some other bearing in your tranny.
Old Feb 11, 2004 | 07:12 PM
how about this.. just replace all of the above, and you'll be trouble free for years
Old Feb 11, 2004 | 08:15 PM
projectEK9's Avatar
Default Re: (infinatenexus)
I had the same problem, might as well replace the clutch while your down there.....
Old Feb 11, 2004 | 08:19 PM
MEANB18's Avatar
Default Re: (projectEK9)
yep, input shaft bearing... here's the link.:
https://honda-tech.com/zerothread?id=596873
Old Feb 11, 2004 | 08:30 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: (MEANB18)
my car is doing the same thing, but it's when the clutch is pushed in, not when it's out. when the clutch is pushed in there is sound like a ball rolling around in a metal circle, it's the strangest thing i've ever heard, i was told when i got the car that the trowout bearing needed to be re-greased but not sure if that is whats going on? would it be smart to go ahead and change out the clutch or just get the throwout bearning re-greased if in fact thats the prob..? any help would be GREAT!! thanks guys
Old Feb 12, 2004 | 11:33 AM
Default Re: (preacherboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preacherboy &raquo;</TD></TR><TR><TD CLASS="quote"> my car is doing the same thing, but it's when the clutch is pushed in, not when it's out. when the clutch is pushed in there is sound like a ball rolling around in a metal circle, it's the strangest thing i've ever heard, i was told when i got the car that the trowout bearing needed to be re-greased but not sure if that is whats going on? would it be smart to go ahead and change out the clutch or just get the throwout bearning re-greased if in fact thats the prob..? any help would be GREAT!! thanks guys</TD></TR></TABLE>
in your case it sounds like a bad throwout bearing. it would be smart to just get a new throwout bearing, and if your clutch is in need of replacement, do that too while you've got it all open.
Old Feb 12, 2004 | 12:34 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (carsaregood)
could be either a bad throwout bearing or input shaft bearing. at first i thought it was the throwout bearing, but i replaced it and the noise was still there. so i narrowed it down to the input shaft bearing.
Old Feb 12, 2004 | 12:39 PM
TABIAS's Avatar
Default Re: (AzntaggeR)
how much would getting a new throwout bearning cost?!?!?
Old Feb 12, 2004 | 12:41 PM
GARBhatch.'s Avatar
And when you start easing off of the clutch, if your car sputters and almost feels like it will stall, it could also be your t/o bearing
Old Feb 12, 2004 | 12:45 PM
TABIAS's Avatar
Default Re: (98Hatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98Hatch00 &raquo;</TD></TR><TR><TD CLASS="quote">And when you start easing off of the clutch, if your car sputters and almost feels like it will stall, it could also be your t/o bearing</TD></TR></TABLE>
yeah i don't have this problem, it just makes a odd sound when the clutch is pressed...
Old Feb 12, 2004 | 12:46 PM
2000CX's Avatar
not to jack the thread or anything but...can these types of noises also happen when the engine is under load...like when you let off the gas to slow down...or even when you pull out during high rpms(3-4500)?
dc2long
Aug 3, 2008 08:52 PM
puertoroc7976
Oct 9, 2006 07:11 AM
vlc92189
Jul 23, 2006 05:01 PM
JDM SLICK
Feb 16, 2005 05:38 PM
Bbasso
Sep 14, 2003 11:17 PM
