mount compatibility?????
in the pic does anyone know if #8 from a 94+ integra will bolt up to a 92-95 civic crosmember
thanks
Modified by 92civeg at 3:25 PM 2/17/2004
Modified by 92civeg at 3:26 PM 2/17/2004
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg »</TD></TR><TR><TD CLASS="quote">in the pic does anyone know if #12 from a 94+ integra will bolt up to a civic frame</TD></TR></TABLE>
Yes it will.
Yes it will.
#12 + #14 are different. The sleeve that goes through them is different lengths on opposite sides. And the one for the left side is smaller from top to bottom, it has a recessed area between the two bolt holes. So if you flip it around so the flanges line up the same the sleeve is in a different position. Also the mounting point on the chasis on the left side has a section of metal about an 1/8th in thick between the two bolt holes, so if you try to bolt the right mount onto it it will hit the "spacer" (sorry, lack of name for this chassis part, also have no idea why it is there other than causing the parts department to make more money selling two different mounts). That's why the right side mount has the slight recess in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4CFED »</TD></TR><TR><TD CLASS="quote">#12 + #14 are different. The sleeve that goes through them is different lengths on opposite sides. And the one for the left side is smaller from top to bottom, it has a recessed area between the two bolt holes. So if you flip it around so the flanges line up the same the sleeve is in a different position. Also the mounting point on the chasis on the left side has a section of metal about an 1/8th in thick between the two bolt holes, so if you try to bolt the right mount onto it it will hit the "spacer" (sorry, lack of name for this chassis part, also have no idea why it is there other than causing the parts department to make more money selling two different mounts). That's why the right side mount has the slight recess in it.</TD></TR></TABLE>
cool thanks a lot
cool thanks a lot
Linh.
25
Sep 24, 2006 06:58 PM
