EG's where did you ground your amp in the trunk?
Old Feb 11, 2004 | 04:33 PM
Quetzolcotl's Avatar
Default EG's where did you ground your amp in the trunk?
I am having a hell of a time finding a proper ground for my amp. I always have a high pitched wine. I have used the seat belt bolts under the seat, the shock tower, the bolts on the floor of the trunck towards the rear, and added a bolt to the side by the shock where there was already a bolt hole. none of these work. I am getting pissed. I tried to drill a new hole too by the spare tire but there are two layers of metal separated by about 1/2 inch. any ideas? and yes I scraped the paint away to reveal bare metal.
Old Feb 11, 2004 | 04:42 PM
h22avid's Avatar
Default Re: EG's where did you ground your amp in the trunk? (Quetzolcotl)
I think this may be the wrong forum for your question but at any rate here's your answer...
Any of the grounds you mentioned will work fine but I think you are missing one key step. You need to take a wire brush, wire wheel, or some sandpaper and expose some bare metal around the surface of the bolt where you are grounding to. You must remove all paint in order to expose bare metal so that you get a good and proper ground.
Old Feb 11, 2004 | 04:43 PM
mike93eh
Guest
Posts: n/a
there must be something wrong with your amp then, cuz all the places you mentioned are good. try getting a inline noise filter..
Old Feb 11, 2004 | 04:47 PM
Nader_D's Avatar
Default Re: EG's where did you ground your amp in the trunk? (mike93eh)
i drilled a hole in the metal, put a screw and it worked
Old Feb 11, 2004 | 07:26 PM
Default Re: EG's where did you ground your amp in the trunk? (Nader_D)
That is weird b/c it does it with my MTX amp and my brand new soundstream. and yes, i exposed bare metal for the grounds. maybe it is the amps.
Old Feb 11, 2004 | 07:32 PM
mike93eh
Guest
Posts: n/a
get a ground loop isolator to get rid of noise..
ALDJ253
Mar 11, 2014 03:41 PM
unknown force
Audio / Security / Video
Mar 20, 2010 08:56 AM
thatasiankidtony
Nov 23, 2006 10:09 AM
juniordc2
22
Jul 18, 2004 09:58 AM
Quetzolcotl
Feb 7, 2004 07:08 PM
