amp grounding/mounting problem?
Old Feb 3, 2004 | 11:44 AM
Quetzolcotl's Avatar
Default amp grounding/mounting problem?
I mounted my soundstream amp onto the back of the rear seat in my civic. The amp is grounded to the seat belt bolt under the seat. When I push the seat back to close it I get distortion through the speakers. It happens when the metal latch touches the lock. Is this because the amp is all metal, has metal mounding screws, and is screwed into the thin metal under the carpet on the back of the seat? Will I have to just change to plastic screws or what?
Old Feb 3, 2004 | 12:07 PM
HONDA-2NR's Avatar
Default Re: amp grounding/mounting problem? (Quetzolcotl)
i had my amp on my backseat for a long time and never had problems. You have me puzzled?
Old Feb 3, 2004 | 12:21 PM
nOOber's Avatar
Seat belt bolts are usually pretty crappy grounding points.
Take out your DMM are measure ( impedance scale)between the negative post on the battery and ... where ever you are going to ground to.
If you find a spot that reads less than one ohm, it should be good.
A wire wheel will sand away any paint/ rust that is sodding your connection.
Old Feb 3, 2004 | 01:38 PM
Spider Man's Avatar
You have a bad ground.
SInce those parts are closely related in proximity it is beign conducted from the point to the lock.
Ground it to a new point.
Old Feb 3, 2004 | 03:10 PM
Default Re: amp grounding/mounting problem? (Spider Man)
is the location bad or is the paint making it bad? any suggestions for grounds in that proximity? the ground wire is only 2 feet long. i'll have to try that multi-meter thing. thanks
Old Feb 3, 2004 | 03:29 PM
Spider Man's Avatar
You don't really need a multimeter.
The seat belt ground is not exactly the chassis of the car.
If you have a drill, drill a hole in the floor of the trunk and ground it there.
Yes take off the paint.
It should be metal to metal contact.
it is a combination of the paint and the location that is making it bad ground.
Old Feb 3, 2004 | 08:07 PM
ludeboy555's Avatar
grounding needs to be on metal surface. remove all the paint and that should fix your prob.
Old Feb 7, 2004 | 11:35 AM
Default Re: amp grounding/mounting problem? (ludeboy555)
so i finally ground off all the paint from around the seat belt bolt. hooking up a wire to the negative side of the battery and testing with a multimeter it read at .5 ohm's. it still didn't work right. guess I'll have to drill my own hole. sucks.
Old Feb 7, 2004 | 07:08 PM
Spider Man's Avatar
yes, you need to find a new ground point.
Arthas
Audio / Security / Video
12
Apr 9, 2012 07:36 PM
silent1jt
Dec 11, 2009 01:50 PM
adrian1281
Feb 19, 2004 05:29 PM
blackhatchy
19
Apr 30, 2003 05:26 PM
rsx03
10
May 10, 2001 09:10 AM
