Stripped studs in head ...
Old Feb 11, 2004 | 03:36 PM
DEVIN22CBR's Avatar
Default Stripped studs in head ...
So come to find out ...The stud holes are pretty much shot to ****. Is there a fix for this that would be cheap and effective ? Thanks
Old Feb 11, 2004 | 03:49 PM
tegasaurus's Avatar
Default Re: Stripped studs in head ... (Sac)
new block
Old Feb 11, 2004 | 03:50 PM
Johnyquest's Avatar
Default Re: Stripped studs in head ... (tegasaurus)
I beleive they are called heli-coils or timeserts. look into them.
Good luck.
Matt
Old Feb 11, 2004 | 03:55 PM
DEVIN22CBR's Avatar
Default Re: Stripped studs in head ... (Johnyquest)
Thanks man , Would Sear have anything liek this ?
Old Feb 11, 2004 | 03:58 PM
DEVIN22CBR's Avatar
http://www.artsautomotive.com/timesert.htm ..Pretty good tool to have around it look like
Old Feb 11, 2004 | 04:15 PM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sac &raquo;</TD></TR><TR><TD CLASS="quote">So come to find out ...The stud holes are pretty much shot to ****. Is there a fix for this that would be cheap and effective ? Thanks </TD></TR></TABLE>
Exactly what threads are stripped?? you gave absolutly no clue but in the head???Do you mean the head bolt threads in the block?If so try heli coiling them as posted earlier.you can get them at any hardware store,but put therm in carefully or you'll re-**** yourself.
Old Feb 11, 2004 | 05:01 PM
DEVIN22CBR's Avatar
Default Re: Stripped studs in head ... (fkned)
Header studs/nuts ..Stripped out pretty damn bad. Sorry
Old Feb 11, 2004 | 05:04 PM
allmotrjdm's Avatar
geese man what are you doing to my baby( lol)
DEVIN22CBR's Avatar
Default Re: (allmotrjdm)
Lol Dude ..I dont know ..***** insanse though. Gremlins!!!
Old Feb 11, 2004 | 10:54 PM
WCI's Avatar
WCI
Default Re: (Sac)
I just took my c5 block to a local machine shop and they helicored the ones that stripped out of the block. do you have ARP head studs. If not I would strongly recomend them so this doesn't happen again if you take the head off. good luck
Old Feb 12, 2004 | 01:12 AM
Fkned's Avatar
Extract them and helicoil em youll be fine
Old Feb 12, 2004 | 06:56 AM
tegasaurus's Avatar
oh, its jus tthe exhaust header studs? lol... just pull the old ones out and re-thread the holes with a tap.
-ryan
Old Feb 12, 2004 | 07:26 AM
DEVIN22CBR's Avatar
Ok can you give me the basic run down of how to re-tap threads please ? My friend has a kit he said he would let me borrow ..But need some help explaining how it works
Old Feb 12, 2004 | 07:57 AM
LoSt is BlaCk's Avatar
ask for a king coil! this one is a bit stronger over the long run! the helicoil is more like a bandage to get you buy! but if yo boost they apparently don't hold up that long!
Old Oct 31, 2005 | 11:19 AM
kevslive95's Avatar
Default Re: Stripped studs in head ... (LoSt is BlaCk)
whoever said helicoils are a quick fix they are wrong. Helicoils are a great replacement for aluminum threads and they are stronger than aluminum threads. alot of race teams will not build a motor that is aluminum threaded without replacing all the threads with helicoils because they are constantly tearing down and rebuilding the motors. I have been there and done it but one thing you must take your time in doing it or have someone that knows what they are doing do it for you.
Old Oct 31, 2005 | 01:53 PM
Jared's Avatar
a timesert is the best way to go
Old Oct 31, 2005 | 05:11 PM
simike's Avatar
Default Re: (Jared)
Try this https://honda-tech.com/zerothread?id=1382274 It's a sticky at the top of the FI forum.
91-lsvtecsi
Jan 28, 2006 09:47 AM
rollydc69
Dec 2, 2005 06:25 PM
mike93eh
Sep 5, 2005 09:35 AM
94integragsr
Jul 13, 2005 06:18 PM
Thasty
Honda Motorcycles
10
Jun 24, 2004 09:20 PM
