DIY Clear sunroof plug
For those of you who didnt read up on what happened to my original sunroof, check it out here https://honda-tech.com/zerothread?id=706861
I was tired of not being able to drive my car when it was raining or it sucked when in the morning the inside of my windows would get all fogged up. I said screw it and decided to go along with making my own plug but out of acrylic glass which I got at homedepot for about $30. Right now it kinda looks messy because it has sylicone all over, but i'll clean it up this weekened and take some final pics. But this is what it looks like now.
Modified by t0eKnEe at 5:16 AM 2/22/2004
cool, can you take a pic of the hardware you used, especially the L bracket. id like to know how to find this hardware piece without having to fab em myself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">cool, can you take a pic of the hardware you used, especially the L bracket. id like to know how to find this hardware piece without having to fab em myself.</TD></TR></TABLE>
Damn, I threw away the packaging from that. Its a 4 pack of L brackets that include the screws and nuts with it. I had to modify them for the back because the lip was small to screw down the bracket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch »</TD></TR><TR><TD CLASS="quote">Does it have a gasket or something to keep it from leaking?</TD></TR></TABLE>
The plug was cut exact so its pressure fit on there, I used clear waterproof sylicone around the plug and in the screws. NO water is getting in that sucker.
cool, so whered you get em, what are its intended application?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0eKnEe »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">cool, so whered you get em, what are its intended application?</TD></TR></TABLE>
I got them at homedepot, it was like $1.50 for 4 universal brackets with the screws and nuts. I forgot the exact namebrand, but if you take off your sunroof assembly and look at the lip where you would bolt them down to, you can see how long of a bracket you would need.
I like that!
You should have tinted that sucker!
I was going to use my stock sunroof and just silicone it shut myself, not a big fan of leaking and whistling with the wind.
Good job!
Good job!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jays91DXhatch »</TD></TR><TR><TD CLASS="quote">I like that!
Good job!
Dont do that, thats how my panel flew off, the rubber seal held on to the sylicone so well, that the panel started to pop up and eventually the wind blew it off. And about the tint, I was thinking of tinting it now, but i'll clean it off some, then get it tinted from the inside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda »</TD></TR><TR><TD CLASS="quote">That is pretty cool, what would you say it weighs?</TD></TR></TABLE>
prolly weighs less than my keyboard. "thats all I could think of right now comparing the weight" Its 1/4" thick. I cant believe I didnt do this long time ago.
Good job!
</TD></TR></TABLE>Dont do that, thats how my panel flew off, the rubber seal held on to the sylicone so well, that the panel started to pop up and eventually the wind blew it off. And about the tint, I was thinking of tinting it now, but i'll clean it off some, then get it tinted from the inside.
honestly, im really glad you did this. i got hounded by the maker of the CF plug about how great his product is and its so worth $300 just because its made of CF and that i shouldnt call it a waste of money ("bling") compared to other materials and options. you seem to have done a great job, and certainly in comparison to $300 for CF, its even better. I was planning on doing the same thing, except with just steel for racing rules, but never got around to it.
btw, they sell window tint paint at hobby stores. its kinda hard to work with actually since its very "thin" liquid, so spray in very light coats and let it dry and make sure everything is clean because the surface tension will cling to any imperfection. i used this when working with RC car bodies made of lexan. but it might work well for what you want.
thats what tyson just said
looks good, you should have used 3M window weld to seal it, works much better, tape off like .25 from the edges, fill, spred with finger, for perfect finish use a ice cube to smooth and let harden over night
man that looks cool good job
i wonder if you can buy some rubber to go arround the glass and the metal to make it look more stock, like the rubber that goes around your windshield. Just a thought
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony »</TD></TR><TR><TD CLASS="quote">man that looks cool good job
Yeah I was thinking of the same thing, I was thinking of using the rubber seal that was on the sunroof originally. I'll go by homedepot again this weekened and see what I can find. And I'm also thinking of cutting the sunroof hole on the headliner to the size of the sunroof plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">honestly, im really glad you did this. i got hounded by the maker of the CF plug about how great his product is and its so worth $300 just because its made of CF and that i shouldnt call it a waste of money ("bling") compared to other materials and options. you seem to have done a great job, and certainly in comparison to $300 for CF, its even better. I was planning on doing the same thing, except with just steel for racing rules, but never got around to it. </TD></TR></TABLE>
I'm not going to touch that argument with a 10' pole, but I will say this...
A reasonable bracket material is aluminum angle stock. Pick up a 4' piece of 1/4" and snip/saw/grind it to your desired lengths. It's just wide enough to hold pop rivets and you can use longer pieces for straight sections and short ones for the curves. And they weigh much less than steel (unless you're using the steel roof plug, in which case you might not care).
The lexan looks good. I would never leave it clear in AZ or I would fry, but you might get away with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis »</TD></TR><TR><TD CLASS="quote">
A reasonable bracket material is aluminum angle stock. Pick up a 4' piece of 1/4" and snip/saw/grind it to your desired lengths. It's just wide enough to hold pop rivets and you can use longer pieces for straight sections and short ones for the curves. And they weigh much less than steel (unless you're using the steel roof plug, in which case you might not care). </TD></TR></TABLE>
Good call, that stuff would work really well! Sturdy and lightweight, and it will provide a lot of support as well.
Alex
Alex
Nice job! It looks good!
I have been playing with acrylic for a few weeks now myself. I am using it to make a fishtank lid. (This is related... kind of - just keep reading.) First I tried .090 thick and now I am using something like .200 thick. Those are the only 2 sizes that OSH hardware carries as they are also the standard thicknesses for replacing glass.
I had to replace the .090 because it bowed in. It severly sagged. I even tried cutting some strips of the .090 and bonding it to the sheet for extra support, but over a couple days it still sagged. So I bumped up to the .200 stuff and it held flat for a few days and then began slowly sagging. It's not as dramatic, but it's still not nice.
This tank has no lights on it and it's held at a solid 80 degrees without any direct sunlight. I'm wondering what your plug will look like after a day in the hot sun! I suggest you find some way of supporting it wih a cross bar or something BEFORE the saging begins!
Here is a genious at work.
I'll have to give ya
for this great craftmanship.
I've being kind of lazy lately to do it myself, collecting parts for my motor build and saving enough money to get my block bored so I can boost again.
Yes I am a boost-a-holic.
Forget that Over priced POS CF plug, $300 but a small piece of CF WTF do they think I am... stupid or something. that's like $20 for a bottle of coke.
Stupid people will pay that ****.
Modified by CRX T-Si at 6:14 PM 2/12/2004
for this great craftmanship.I've being kind of lazy lately to do it myself, collecting parts for my motor build and saving enough money to get my block bored so I can boost again.
Nice job man. Im wondering if its legal for drag events. Im in the process of building my car up for SportFWD and need to ditch my heavy *** sunroof.
I wonder if it'll take a 150 mph pass down the 1/4
