Those with Ground Control coilovers, how long is your spring? Is it 200?
Old Feb 11, 2004 | 12:47 PM
erikiksaz1's Avatar
Default Those with Ground Control coilovers, how long is your spring? Is it 200?
The GC guy told me civic/crx springs should be less than 200, something like 16x, whereas the 200 is for the EG series of civics.
Can anyone verify?
Old Feb 11, 2004 | 01:11 PM
NINJASPY's Avatar
Default Re: Those with Ground Control coilovers, how long is your spring? Is it 200? (erikiksaz1)
200mm=8inches
180mm=7inches
if you dont believe the "gc guy" who is from gc, who can you believe?
Old Feb 11, 2004 | 03:24 PM
erikiksaz1's Avatar
Default Re: Those with Ground Control coilovers, how long is your spring? Is it 200? (NINJASPY)
You're right, guess i was freaking out about it.
But, the guy i'm buying these coilovers from has springs which are 200.64.spring rate. He says that so long as you have the right shock meant for civic/crx, that it'll still work fine, is that true?
Old Feb 11, 2004 | 04:11 PM
Tyson's Avatar
8" springs will work fine, it just wont allow you to go as low as say a 7" or 6" spring would, but why would you WANT to go that low. 8" is fine in terms of fitment. the 64mm/2.5" diameter is also the correct spec too.
Old Feb 12, 2004 | 12:32 AM
travis's Avatar
Default Re: Those with Ground Control coilovers, how long is your spring? Is it 200? (Tyson)
I have run 8", 7", and 6" both front and back on GC sleeves and I never ran out of room with the 8" (meaning they were able to go lower than I wanted them to). And this is with a 500# spring that will compress less than the rates you are using.
2kstreetcivic
Dec 1, 2004 09:12 PM
toooslow
Aug 15, 2003 09:10 AM
x James Bond x
Feb 2, 2003 05:32 PM
HybridGSR1
Sep 23, 2002 01:58 AM
garados
Jun 20, 2002 10:32 AM
