Rod bearing tang towards intake or exhaust?
or does it matter?
Sitting at work thinking about it right now. I've assembled my rods and pistons, but didn't pay attention to the above mentioned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">dont they only fit in the rods one way...?
the bearings fit the rod one way but the piston must face a certain direction and can be put on the rod the wrong way
</TD></TR></TABLE>the bearings fit the rod one way but the piston must face a certain direction and can be put on the rod the wrong way
BUMP this back from the dead.
I know the rod's bearing tang faces the exhaust side, but there are two tangs. One on the rod and one on the rod cap. Does the cap tang face the same way? Or is it opposite?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">BUMP this back from the dead.
I know the rod's bearing tang faces the exhaust side, but there are two tangs. One on the rod and one on the rod cap. Does the cap tang face the same way? Or is it opposite?</TD></TR></TABLE>
same way, both on the exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbiker207 »</TD></TR><TR><TD CLASS="quote">
same way, both on the exhaust</TD></TR></TABLE>
O really? Well, my caps are backwards then...
glad this is back up. good info. (although no one as actually said a specific reason why, other than that's how it's designed) just in the middle of my D16 build and followed a b-series guide that said tangs to the Ex.
-Luke
-Luke
I don't think it really matters if it would go on the intake side or exhaust side, but exhaust side is simply Honda (maybe even industry?) standard. The tangs only really act to locate and center the bearing in the cap and rod bores.
what i was saying was i took apart a gsr motor that was not touched by any 1 and found the tangs on the intake side. does it matter or not, i know all the tangs have to be on the same side but does it really matter intake or exhaust
i think the dilemma is that you can assemble the rod to the piston 2 ways, but the piston should go into the bore only 1 way because the valve reliefs should match the proper valves. because of this, it is EASILY possible to have the bearing tangs facing the wrong direction. i still don't know why it is the wrong direction, it might have something to do with the oiling holes lining up properly with the oiling holes on the crankshaft.
No where in the helms does it state the tang has to be on the exhaust side. It merely mentions that the tangs on the rod cap and rod itself must matchup
on chevys i know that it has to do with preventing the rod bearing from spinning, not sure about 4 cylinders though, im double checking my service manual now for this
ok so by this logic the tangs would have to point to the exhaust side, just took a look at the oiling hole on one of my stock LS rods, oddly enough though, my crower rods do not have this oil hole, nor do they have an oiling hole in the bearing area.
Yeah for oem stuff ok, but aftermarket? I'm going to redo my pistons so they are correct but Id really like to know the engineering reason behind it.
I have a feeling I'm going to pulling a couple clips
