installation of skunk2 intake manifold---the aftermath, help
to check for leaks, let the car idle and spray around the mani with carb cleaner. if the idle fluctuates, the leak is there. did you replace your gaskets?
I have 2 friends with that manifold. 1=b16 2=gsr and they both had the same problem with the idle. It ended up being the IM gasket even though they replaced it w/ a new 1. Hope this helps
germanEE8
Feb 25, 2004 08:56 AM
