greddy blue box - where is it?
Old Feb 11, 2004 | 12:07 PM
soulrider4ever's Avatar
Default greddy blue box - where is it?
yo whats up all...
my first post
just got a new civic hatchback, 93 with a b18c1 swap and greddy 18g turbo
got a apexi vafc...
im trying to find the blue box that comes with the turbo to make sure its working properly.
310cc injectors
i dont know what it looks like or where to find it... im a newb to turbo's and im not mechanic..
i dont have hondata or a vafc hack.
thanks
Old Feb 11, 2004 | 01:12 PM
UNDER PRESSURE's Avatar
Default Re: greddy blue box - where is it? (soulrider4ever)
It should be near the ecu on the passenger's side, maybe under the carpet?
Kazz's Avatar
try looking around where ur ECU is should be around there
Old Feb 11, 2004 | 01:25 PM
Default Re: greddy blue box - where is it? (JuuKe_EM)
no where to be seen under there..
i ripped out the carpet.. got the ecu its a obd1 95 gsr.. got all the wires from the apexi vafc there no problem, thats installed properly, but i dont see any blue box there at all!!!!
yikes!
no beatings
anybody got any recomendations to set VAFC WOT to??? +36 ?? maybe??
im getting dyno tuned tomorrow.. but i cant believe theres no blue box!
Old Feb 11, 2004 | 01:33 PM
EJ1 wilcox's Avatar
Your blue box should be wired into your ECU harness. If you pulled back the carpet exposing the ECU and there was no blue box.... you must not have one?
Is your car running? You said you have a VAFC but no hack? What fuel management are you using?
Old Feb 11, 2004 | 01:38 PM
Mr Boston's Avatar
Default Re: greddy blue box - where is it? (koreanwilcox)
I really really hope you have some sort of fuel mangement running
Old Feb 11, 2004 | 01:53 PM
Default Re: greddy blue box - where is it? (nGo)
well i just double checked and all i see is the vafc wires.. i dont know about the fuel management running... ouch!
im getting it dyno'd tomorrow.. would that help at all??
car runs fine....
my air/fuel autometer, says im running rich most of the time until i punch it and the turbo and vtec kicks on then it goes lean!
Modified by soulrider4ever at 11:36 PM 2/11/2004
Old Feb 11, 2004 | 02:38 PM
p0gi's Avatar
maybe you have an fmu.
Old Feb 11, 2004 | 02:45 PM
Default Re: greddy blue box - where is it? (p0gi)
how would i know if i have an fmu???
someone said have 2 fuel something or others.. man im sorry i'll just have to post a picture of the engine and let me know.. although its dark here, so i cant do it tonight.
Old Feb 11, 2004 | 07:07 PM
iwhichisme's Avatar
maybe youre just not running a bluebox, and instead a fmu w/missing link, different injectors, fuel pump etc..
Old Feb 11, 2004 | 09:25 PM
whackassfawker's Avatar
How are you going to make sure it works properly when you can't even find it? You may notice that the wires are spliced to the ecu.l
Old Feb 26, 2004 | 09:10 AM
Akiraboy's Avatar
Default Re: greddy blue box - where is it? (iwhichisme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">maybe youre just not running a bluebox, and instead a fmu w/missing link, different injectors, fuel pump etc..</TD></TR></TABLE>
Can you run a blue box without the fmu and missing link.
Can you run a blue box with a vafc?
Old Feb 26, 2004 | 09:23 AM
p0gi's Avatar
Default Re: greddy blue box - where is it? (akiraboy)
yes , but I wouldnt recommend using the vafc on top of the blue box. Its better just to get rid of the box and get a better engine management system (hondata, aem, emanage), one that is tunable
Old Feb 26, 2004 | 12:10 PM
Akiraboy's Avatar
what would you recommend for an EE 90 civic with a d16a6 block, y8 head and
.078" gasket?
I have a msd rpm switch.
Should I use this instead of a vafc?
Then use the greddy blue box?
I'm so confused.
Old Feb 26, 2004 | 12:46 PM
Matt B's Avatar
are you sure your ecu isn't chipped?
gunmetalcivic
Jun 14, 2004 10:53 PM
0 0 0
May 18, 2004 08:45 AM
GForceInteg
May 4, 2004 08:49 AM
willyboyK20
Feb 24, 2002 01:34 PM
