b18c1 pistons in a b18 1/b (cr issue)
If I put 9:1 gsr pistons in my ls block, with ls spec rods and crank...what will my compression ratio do?
Do the pistons stay the same, or do they fluctuate in compression?
what can I expect?
Also, what rings do i use, will the rings be the same for the piston type and the 81.50 size?
what can I expect?
Rings will not be the same--definetly.
If you have some time you can goto c-speed.com and they have a compression ratio calculator using oem parts or you can fill in the blanks if you have aftermarket piston specs. You will have to convert dome size from standard to metric if i remember correctly.
Adi Radoncic
Aug 24, 2003 02:15 PM
