Differences btwn '90 CRX HF and Si
Old Oct 9, 2001 | 06:04 AM
White Dragon's Avatar
Default Differences btwn '90 CRX HF and Si
I was just wondering what all of the differences were between the HF and Si model.
Old Oct 9, 2001 | 06:12 AM
ZygSpeed's Avatar
Default Re: Differences btwn '90 CRX HF and Si (White Dragon)
HF -- 65-70 hp, 50- 60 or so highway mpg, no sunroof, 0.655 fifth gear, 13 inch wheels prolly about 2000+ lbs.
Si -- 106-108 hp, 16V motor, 7200 redline, 30 ish mpg, 14 inch alloys, sunroof, better brakes. about 2200+ lbs.
Old Oct 9, 2001 | 07:05 AM
rainforest's Avatar
Default Re: Differences btwn '90 CRX HF and Si (zygspeed)
hf crappy intakemanifold throttle body no displacement and they suck. si is cool.
Old Oct 9, 2001 | 08:09 AM
ososlow's Avatar
New User
si is col until you put a B16a in a CRX. Then it's a little faster.
Old Oct 9, 2001 | 08:19 AM
allmotorEG-SI's Avatar
Default Re: Differences btwn '90 CRX HF and Si (rainforest)
well as far as performance goes yes it sucks. really really bad. I don't know of a slower car except a metro or first gen civic. but it does mean a nice lightweight car for a good race car. that is if you do an engine swap. right so its not that all bad.
Old Oct 9, 2001 | 02:59 PM
Safir's Avatar
http://resource.crx.org/crx_informat...fications.html
should have more objective answers to your questions, although everythign said here so far is technically correct.
Old Oct 9, 2001 | 03:19 PM
martini's Avatar
Default Re: Differences btwn '90 CRX HF and Si (Safir)
I think the biggest deal, for me, is that the Si has 4 wheel disc brakes.
Old Oct 9, 2001 | 03:21 PM
RyanR's Avatar
What I want to know is how the DX gained 200lbs from 88 to 90?
Old Oct 9, 2001 | 03:27 PM
MiraiZ's Avatar
Default Re: Differences btwn '90 CRX HF and Si (97TypeR_9)
DX has a 2+2 configuration...(like a back seat for short granny and small children) whereas the HF has no back seat (a total 2 seater)
DX has heavier doors and interior paneling than the HF
HF has a lighter engine and smaller gas tank.
HF has a lot less amenities than the DX
add it all up,..its about 200lbs..
Old Oct 9, 2001 | 03:29 PM
RyanR's Avatar
Default Re: Differences btwn '90 CRX HF and Si (MiraiZ)
No, i know why the HF is lighter, but I want to know how the DX model gain 200lbs from the 88 model year to the 90 model year.
Old Oct 9, 2001 | 03:32 PM
MiraiZ's Avatar
oooh...ok
well the suspension is diffrent for one thing... and the interior i completely different...more ammenities offered in 1990...not sure if it all adds up to 200lbs though...probably more like half that...
Old Oct 9, 2001 | 03:50 PM
RyanR's Avatar
how is the suspension different? It's just the rear LCA's, right? Yeah, I don't see how it could be 200lbs different. Maybe 100, but not 200.
Old Oct 9, 2001 | 05:12 PM
4wsB21a's Avatar
New User
i have a 90 dx and there is no back seat. what are you talking about? if someone sat on the compartment that is back there, they would go right through it - it is just plastic. and how did you come up with the hf having a smaller tank? the second gen should all have the same size tank, where the first gen si has a 13.5 gallon tank - all other crx's are supose to have the 10 gallon tank.
Old Oct 9, 2001 | 08:21 PM
bigD's Avatar
7200 redline? What year si has that? My redline is at 6500
Old Oct 10, 2001 | 02:01 AM
MiraiZ's Avatar
Default Re: Differences btwn '90 CRX HF and Si (crxplus)
I had an 89 dx....it had a fold down back seat
Old Oct 10, 2001 | 07:38 AM
RyanR's Avatar
Well in Japan the CRX got a rear seat, all US CRX's have that storage compartment. The HF does have a smaller tank too. It's like 10.9 gallons instead of 11.5 like the DX and Si.
Old Oct 10, 2001 | 08:05 AM
crux131's Avatar
The weight gain between 88 and 90 ( Actually 89 ) is due to the change from rear pillar mounted seatbelts, to the door mounted models 89 and up CRX'x have. They had to add more reinforcement for it to pass federal regulations.
Old Oct 10, 2001 | 08:14 AM
memphiss13's Avatar
Default Re: Differences btwn '90 CRX HF and Si (2000-B18C1)
it redlines at 6500, but the rev limiter is at about 7000-7200.
Old Oct 10, 2001 | 09:38 AM
RyanR's Avatar
Default Re: Differences btwn '90 CRX HF and Si (crux131)
So the reinforcement alone adds 150-170lbs? I pulled out the stock seat belt assembly from my 91 DX this weekend and it weighs no more than 15lbs for both of them.
Old Oct 10, 2001 | 05:02 PM
wronghand's Avatar
Why don't you take the doors off and weigh them. That is probably where you will find most of the difference.
Grnade
Apr 1, 2005 12:05 PM
lilneep16v
Feb 14, 2005 05:21 AM
JBk24crx
Oct 13, 2003 07:34 PM
BigBCOD
28
Jul 10, 2002 04:48 AM
Ltech
Dec 14, 2001 12:57 PM
