heres the dilemma, any help appreciated....
Old Feb 10, 2004 | 09:37 PM
troubled91accordpos's Avatar
Default heres the dilemma, any help appreciated....
The only way the car will crank is if the clutch pedal is out. This symptom is only interittent though. However NO Accessories will work (ie, power windows, locks, seatbelts, headlights.) I installed a new electrical portion of the ignition switch and found no change of symptoms. I am unable to read the codes very well so the best codes I could come up with would either be a 18 or a 28. Either way neither code is listed. Any help would be greatly appreciated. thank you -Matt
1991 accord LX 5 Speed
Old Feb 10, 2004 | 09:43 PM
Oh Crap's Avatar
Default Re: heres the dilemma, any help appreciated.... (troubled91accordpos)
Check your fuses? Did you do anything/or have anything done to the car before it that started happening?
Old Feb 11, 2004 | 09:27 AM
Default Re: heres the dilemma, any help appreciated.... (Oh Crap)
The fuses are all ok, the grounds all checked out too. I have someone telling me that my main computer (ecm) may be out due to the fact I can only pull codes that are not existent. Thank you for your reply I am just out of ideas. -Matt
Also there was nothing new done to the car other than a cd player about a month and a half ago. thanks again
unbreakable_35
10
Dec 15, 2008 05:37 PM
Tip14
Oct 8, 2007 04:38 PM
integra*RS*
Mar 2, 2007 04:15 PM
sweettart
Audio / Security / Video
Jun 9, 2006 04:50 PM
aaaabbbb
12
Feb 28, 2005 08:24 PM
