Pondering...All motor D15
Old Feb 10, 2004 | 07:44 PM
*Boostwerks*'s Avatar
Default Pondering...All motor D15
Anyone have a modded D15?
I'm really looking into doing the cheapest ITB setup as possible for my 89 Civic hatch.
Thinking...
SI, or Exospeed cam
my F4i ITB setup (obviously with a MPFI swap).
Cheap *** header
PM6 with an AFC
Thoughts?
Old Feb 10, 2004 | 07:51 PM
GoFastMotorSports's Avatar
Default Re: Pondering...All motor D15 (Bryson)
What are your goals? Street or track
Old Feb 10, 2004 | 07:59 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Pondering...All motor D15 (GRCCRX911)
Throw in some high compression pistions(somewhere in the area of 13-14:1), fatty injectors get a good head job and some high octane fuel (like 120) an hit the dyno, get it tuned and hit the strip. O is this gonna be a DD? If so, scratch the high comp pistions. Just my 02 cents tho.
Blaze
Old Feb 10, 2004 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRCCRX911 &raquo;</TD></TR><TR><TD CLASS="quote">What are your goals? Street or track</TD></TR></TABLE>
This is my daily driver. The main goal is just to get decent power (maybe 120-150whp) with as little money as possible.
as far as the internal build up...NO. I would if this was a ubber race project, but I'm just looking for a fun cheap lil ITB project.
Old Feb 10, 2004 | 08:30 PM
ThatRicerDaniel's Avatar
I believe you would be happier later on putting money into somthing with a little more potential. just my .02 .
Old Feb 10, 2004 | 08:43 PM
Default Re: Pondering...All motor D15 (NitrousDreamz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousDreamz &raquo;</TD></TR><TR><TD CLASS="quote">I believe you would be happier later on putting money into somthing with a little more potential. just my .02 .</TD></TR></TABLE>
Hehehe...its funny you say that. I have a CRX with a 84mm built B18C1 with a GT35E setup...hoping for 500whp.
I don't need another car with tons of power!
Old Feb 11, 2004 | 04:53 AM
slow hatch's Avatar
since you already have a car with plenty of HP. I think it would be cool to just mess around with some different setups on the lil D15. best of luck to ya
Old Feb 11, 2004 | 07:48 AM
USDM 4G VTEC's Avatar
Default Re: Pondering...All motor D15 (slow hatch)
try doing it like the old school SCCA rules
take the D15, rebuild it, put some independed WEBERS on it..
bump compression and the wildest cam u can get
at least u should get a low 15, high 14 car with that giving u (realistic 125whp) and u shall have fun
Old Feb 11, 2004 | 08:52 AM
Newt Dog's Avatar
Put some piston's and rod's in it.. then add 8psi with a snail
Old Feb 11, 2004 | 09:01 AM
Default Re: Pondering...All motor D15 (Newt Dog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newt Dog &raquo;</TD></TR><TR><TD CLASS="quote">Put some piston's and rod's in it.. then add 8psi with a snail </TD></TR></TABLE>
First of all, no. secondly the D15 uses different rods from the D16, so that would be expensive as ****. Third, NO.
Old Feb 11, 2004 | 10:18 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
bryson, consider acura or honda pistons to raise the CR. ECU!!
i can help you out with chipping it if you'd like, ROM editors are not that hard to use.
Stan
Old Feb 11, 2004 | 10:23 AM
T S R Performance's Avatar
Default Re: Pondering...All motor D15 (Stan D)
d15 block, 1991 CRX Si head, port and polished head(soon), JG cam, stock cam gear for now, DC header, AEM intake, bored out throttle body, 1991 CRX Si LSD trans. Thats my setup, in a 1989 4 door with pwoer everything and on 15inch GSR rims it did 15.2 without port and polish yet.. now i have it in a CRX, hopefully mid 14's.
If you want a fast d15 you can put ZC pistons in it and a Vtec head on it with a skunk 2 cam and VAFC and blah blah blah. Im doing that (zc pistons, skunk 2 cam) and also supercharging it. im into d15-d16's too. tell me how it goes and hope i was a little bit informative on what you want to do.
Old Feb 11, 2004 | 10:26 AM
Default Re: Pondering...All motor D15 (CivicHatchSOHC)
Im also going to be running the bisimoto header too when i do the supercharged setup
Old Feb 11, 2004 | 10:57 AM
HumanResource's Avatar
STG4 Exospeed cam, Raise compression and leave it to the headwork to make the power-
ALSO upgrade the rods
alscrx
15
Sep 14, 2008 04:56 PM
Turbo_squard
Dec 14, 2006 11:37 AM
B18C Turbo
Nov 7, 2006 05:34 AM
bee18
38
Aug 27, 2005 11:35 AM
Drizzo
12
Feb 4, 2004 08:14 AM
