I need Help with wiring the Vtec wire
Old 10-08-2001, 09:27 PM
New User
casualxboi's Avatar
Default I need Help with wiring the Vtec wire
i need help with wiring the vtec wire in a 92-95 civic hatchback..i just swapped a b18c1 in there and need to know waht wires i need to cut and where do i have to plug it in to??? help needed...
Old 10-08-2001, 09:39 PM
markpaco's Avatar
Default Re: I need Help with wiring the Vtec wire (casualxboi)
http://hybrid.honda-perf.org/tech/info.html#B18EG6
Old 10-09-2001, 04:36 AM
maxim's Avatar
Default Re: I need Help with wiring the Vtec wire (markpaco)
I just wired up an Apexi V-AFC to my 2000 EX last weekend and if I remember correctly it was the green wire with the yellow stripe. There are wiring diagrams in service manuals that you can pick up at your local auto parts store if you want to be sure.
Old 10-09-2001, 06:21 AM
VTC_CiViC's Avatar
Default Re: I need Help with wiring the Vtec wire (maxim_force)
Actually there are two wires, the VTEC pressure switch and the VTEC soleniod, both need to be wired correctly.
Old 10-09-2001, 06:30 AM
New User
Kalokohan's Avatar
What year is the B18C1? What kind of ECU are you using? The IAB will be tricky if you have an OBDII engine. Check out the link given to you.
Acidcrakker
11-08-2007 02:39 PM
ilovemyb16a
05-18-2006 12:58 PM
noricercrx
05-06-2002 08:18 PM
Quick Reply: I need Help with wiring the Vtec wire
