CRX dx with new zc swap, Codes 7 & 14...Suggestions???
I just completed everything on a ZC swap in my 90 CRX dx, I followed the wiring to spec. I started it up and it idles fines but when I give it some fuel, It bogs out and wont go over 2500-3000 rpms. Im running an 88 Integra ECU, it is throwing me #7 and 14 codes, I checked the TPS (code 7) and the IAC but both looked fine. Any suggestions?
Code 7 (TPS, black thingie on throttle body) --- did you flip the wires(grren/white and yellow/white)? the DX TPS works backwards
Code 14 (IAC) -- 2X check your connections and wiring(soddered if possible). swap sensors if all else fails.
[Modified by Speed PHreak, 4:58 PM 10/9/2001]
I got mine from MMR in Brentwood, MD next to D.C., they had like 20 in stock when I went up there.
Also try Noyan USA in Mannassas, VA , I don't have any numbers but 411 does.
altfuelneeded
25
Sep 30, 2011 10:08 AM
xtremcrx77
Oct 9, 2001 03:41 PM
xtremcrx77
Oct 9, 2001 09:01 AM
