rough idle
Old Feb 10, 2004 | 05:19 PM
-516-Jpolly's Avatar
Default rough idle
everytime im at a light or stopped or w/e there is an annoying vibration the goes on in the front...when i put it in nuetral the vibes go away...but when its in drive its still there..i was told to get my fuel injectors cleaned and that helped for a few weeks..now the vibrations are back..not sure what to do...
Old Feb 10, 2004 | 05:46 PM
The_Todd's Avatar
Farts in the shower
Default Re: rough idle (-516-Jpolly)
I would try some BG-44K...its a total fuel systems cleaner, it does wonders to your car, costs about 15-20 bucks a can. Also depending on how many miles are on your car/engine I would also suggest motor mounts, usually a tell-tale sign of bad mounts is a rough idle.
Old Feb 10, 2004 | 06:01 PM
cd555's Avatar
How many miles are on your car? You might want to look into getting your fuel filter changed it could be clogged. But most likely its an engine mount.
Old Feb 10, 2004 | 08:06 PM
blindguardian37's Avatar
your iac (idle air controll) could be cloged, i had the same problem with my car a few months ago. its on the intake manifold 2 bolts to take it off, and just clean it with some brake cleaner let it dry and put it back on. it takes all of 15 minutes and makes a huge differance
Old Feb 10, 2004 | 10:47 PM
The_Todd's Avatar
Farts in the shower
Default Re: rough idle (blindguardian37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blindguardian37 &raquo;</TD></TR><TR><TD CLASS="quote">your iac (idle air controll) could be cloged, i had the same problem with my car a few months ago. its on the intake manifold 2 bolts to take it off, and just clean it with some brake cleaner let it dry and put it back on. it takes all of 15 minutes and makes a huge differance</TD></TR></TABLE>
I thought carb cleaner worked better
Old Feb 11, 2004 | 12:45 PM
Perfectionist's Avatar
Default Re: rough idle (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">
I thought carb cleaner worked better </TD></TR></TABLE>
It's cetainly safer for the plastic parts in there.
Old Feb 14, 2004 | 07:43 PM
Default Re: rough idle (Perfectionist)
thier basically the same thing more or less
Old Feb 17, 2004 | 02:24 PM
First Honda 1976's Avatar
If the rough idle causes RPMS to Drop or Rise above normal idle rpms, look at tach. Then buy some Pro Honda - Throttle Plate and Induction Cleaner 14oz Spray Can about $6.00 at Honda Dealer and Clean your Throttle Body with it . The throttle body gets varnish on it that needs to be cleaned off.
decode33
Honda CR-V & Element
Mar 21, 2011 05:36 PM
DaChoZn1
Jan 6, 2011 08:45 AM
shreddinryguy
Jun 13, 2006 11:05 PM
vtechatch
Aug 10, 2002 06:54 AM
maxxdout
Jun 21, 2002 06:04 AM
