88 CRX DX Pieces on an 91 CRX Si? WILL THEY FIT?
Old Feb 10, 2004 | 05:00 PM
jedubz's Avatar
Default 88 CRX DX Pieces on an 91 CRX Si? WILL THEY FIT?
Okay right now as many (or few) of you may know I crashed my 1991 CRX Si and need body pannels. Here's a few questions. I have a friend with a donor 1988 CRX DX and I need to know if I'm okay doing this
1) Will the hood fit? I assume it will because they never say "ZC hood for so and so year"
2) Will the fenders fit?
3) Will the windshield fit?
Old Feb 10, 2004 | 05:03 PM
bryant's Avatar
Default Re: 88 CRX DX Pieces on an 91 CRX Si? WILL THEY FIT? (jedubz)
1. yes
2. yes
3. yes
Old Feb 10, 2004 | 05:07 PM
jedubz's Avatar
AWESOME. I think all of them together are going to run me $100 US... Now if only I can figure out how to get the windshield off
Old Feb 10, 2004 | 05:08 PM
EL Vap133's Avatar
I thought the fenders would be different for the 88 and 91 because of the corner light screws?
Old Feb 10, 2004 | 05:09 PM
ghettocrxsi's Avatar
Default Re: (jedubz)
You need to get a window knife. they should not be that much. You just want to use the window knife to cut the adhesive/ moulding stuff and after you have that done. Be careful not to break it when you are pulling it out.
Old Feb 10, 2004 | 05:26 PM
c for sea's Avatar
i thought so too, el vap 133. also the fender molding is different so that'll look fubared. the rest of the car, beveled mouldings then when you get to the 88 fender, you see a flat, fat moulding. heheh.
Old Feb 10, 2004 | 05:28 PM
XrcR6's Avatar
Default Re: 88 CRX DX Pieces on an 91 CRX Si? WILL THEY FIT? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I thought the fenders would be different for the 88 and 91 because of the corner light screws? </TD></TR></TABLE>
The screws that the 88-89 corner lights use, screw into plastic inserts that fit in the square holes in the fender. The 90-91's have plastic inserts that accept the slotted tab version of the corner lights. So the metal fenders are all the same. The difference is in those little plastic pieces.
Old Feb 10, 2004 | 05:30 PM
kid-honda's Avatar
88-89 fneder will work on on 90/91's with no problems, I have done it.
Swap corner clips and moulding, not vary hard people.
Old Feb 10, 2004 | 05:33 PM
EL Vap133's Avatar
Default Re: 88 CRX DX Pieces on an 91 CRX Si? WILL THEY FIT? (XrcR6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XrcR6 &raquo;</TD></TR><TR><TD CLASS="quote">
The screws that the 88-89 corner lights use, screw into plastic inserts that fit in the square holes in the fender. The 90-91's have plastic inserts that accept the slotted tab version of the corner lights. So the metal fenders are all the same. The difference is in those little plastic pieces.</TD></TR></TABLE>
Ahhh I see, I've never touched any other crx but my 88....lol
SoClose
Aug 25, 2005 04:53 PM
flatblk
Jul 30, 2004 05:46 PM
theclutchpoppa
May 25, 2003 12:36 AM
turbodav
14
Mar 27, 2003 09:49 PM
shoebox
Oct 13, 2002 03:51 PM
