aftermarket lower arms for EF
https://honda-tech.com/zerothread?id=734963
https://honda-tech.com/zerothread?id=728016
check those out, they're not the best I know. But I learned a few things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XrcR6 »</TD></TR><TR><TD CLASS="quote">If your talking about LCA's, go here:
http://store.hybridgarage.com/...0008D </TD></TR></TABLE>
those are so bling bling
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=734963
those are so bling bling</TD></TR></TABLE>
Yeah, they are. But I was surprised to see them post the FEA graphs of the design. BTW, they're also the exact same brand as the first Ebay link in the first thread you put there. They're just the ITR-style (eyebolt shock), which it seemed like he specifically wanted. Only place I've seen them actually post a picture of that version, most places make you switch to a fork-style rather than making two versions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 »</TD></TR><TR><TD CLASS="quote">Use the 88/ITR rear lowers....</TD></TR></TABLE>
so you're saying ITR SSR LCA's will fit 88-91 Civics?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FkingSUV »</TD></TR><TR><TD CLASS="quote">from what i hear eg lca's fit fine even on ef's</TD></TR></TABLE>
thats what i thought
WHY? He's looking for aftermarket ones... not stock ones.
Here's aftermarket one's (again)
SPC makes a set. No where near as bling as those.
Sold through NOPI and other fine retailers.
http://www.spcperformance.com
Guys, you misread what he said, he said for an EF8 not a ED9...he has a real deal SiR so its the same as the ITR ones and i havent seen any made...what you guys are showing will work for the ED chassis. If he wanted to use the aftermarket ones you showed him, he needs to use different rear shocks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">Guys, you misread what he said, he said for an EF8 not a ED9...he has a real deal SiR so its the same as the ITR ones and i havent seen any made...what you guys are showing will work for the ED chassis. If he wanted to use the aftermarket ones you showed him, he needs to use different rear shocks...</TD></TR></TABLE>
He has the same shock that fits the first real response show to him... the ones made by function 7. ITR and the 88 CRX also have the same type of mount for the shock as the JDM EF8 and EF9.
actually function7 makes some for the 88 CRX
'88 ed9, ef7, ef8 and ef9 have the same lower arms, they are interchangeable
least they were when we changed them from a scrapped ef9 on to an ef7, and then took the ef7 ones and put them on an ef8!
