CTR pistons vs. ITR pistons
itr pistons will slightly lower your compression p30 pistons will bump you to 10.4:1 and ctr pistons will bump you to somewhere around 10.8~11.0 which will make the most power when tuned.
The B16A's stroke kills any potential you have to raise your compression above ~10.91:1 (with PCT slugs)... That gain isn't very significant but if it's the compression you're looking for then running OE pistons is fine... If you want to go higher then I would recommend so using aftermarket pistons... Good Luck
EDITED: The 11.19:1 that I had previously figured was the calculated when running a P72 cylinder head...
Modified by Kataku2K3 at 11:36 AM 2/10/2004
Ruben19
19
Jan 9, 2006 09:13 AM
aris04
Jun 7, 2004 12:03 PM
