2cd O2 sensor for obd0 sir?
Old Feb 9, 2004 | 07:43 PM
turbo sol's Avatar
Default 2cd O2 sensor for obd0 sir?
well I have a friend with a DX hatch and a SIR engine in it. He needs me to help with the wiring, to my understanding the MPFI has been done and the car used to run before he destroyed the axles bc of bad mounts. so i think that part of the swap is fine
according to the site
http://b16a.honda-perf.org/theswap.html
it seems like i have 4 more wires to run
•oil pressure
•knock sensor
•vtec seliniod
•2cd O2 sensor
can i tap into the primary O2 sensor for the second one or even leave it off?
i have done an obd-1 d16z6 swap but this is a little different. thanks for you help.
Old Feb 10, 2004 | 05:33 AM
turbo sol's Avatar
Default Re: 2cd O2 sensor for obd0 sir? (turbo sol)
up up and away, for the day crowd.
Old Feb 10, 2004 | 05:58 AM
Fobtions's Avatar
if hes running the stock exhaust manifold there should be two o2's there. if not get another bung welded on, or get the ecu chipped.
Old Feb 10, 2004 | 06:08 AM
virginia_dude's Avatar
yes per the PW0 and the PR3 both control cylinder pairs not the entire engine, use both, one reads pairs 1-3 and the other 2-4 not sure which is which however.
Pairing or chipping both will lead to not so great milage.
Old Feb 10, 2004 | 08:56 AM
turbo sol's Avatar
Default Re: 2cd O2 sensor for obd0 sir? (virginia_dude)
i know he has headers on the car, but i am not sure if it has a second bung for the other O2 sensor.
coudl i just weld another bung right next to the first one?
Old Feb 10, 2004 | 01:54 PM
will like I said if one doesn't see 1+3 and the other 2+4 seperately its no going to run right.
Old Feb 10, 2004 | 02:06 PM
Initial DA6's Avatar
if you tap into the second O2 sensor this will split the strength of the one signal. i'm not sure how well the car will run (or not run) like this. for now, i have my B16 running with just one O2 sensor. it runs, but i'm sure its not up to 100% power since i'm not using both sensors. so to answer your question, yes you can run with just one sensor watching over a pair of cylinders.
allsho
Feb 19, 2007 06:12 PM
Nisif
Mar 16, 2005 08:53 PM
virginia_dude
Feb 2, 2004 08:19 AM
rice4life
Jun 26, 2003 03:39 PM
CiViC SiR
Jul 10, 2002 04:30 AM
