Ground control upper mounts, how much extra suspension travel?
Old Feb 9, 2004 | 07:27 PM
erikiksaz1's Avatar
Default Ground control upper mounts, how much extra suspension travel?
Ground control's own site still says "XXmm of travel"
Does the box or instructions have anything more specific?
Old Feb 9, 2004 | 07:54 PM
Lo-Buck EF's Avatar
Default Re: Ground control upper mounts, how much extra suspension travel? (erikiksaz1)
https://honda-tech.com/zero...age=4
i picked up about 1.25" more travel.
Old Feb 9, 2004 | 08:48 PM
Steve91's Avatar
It gives 3/4" more travel. I've confirmed that with GC.
Old Feb 9, 2004 | 08:49 PM
erikiksaz1's Avatar
Default Re: Ground control upper mounts, how much extra suspension travel? (Lo-Buck EF)
Awesome, thanks!
Old Feb 9, 2004 | 09:06 PM
GraphiteAccord's Avatar
Default Re: Ground control upper mounts, how much extra suspension travel? (Steve91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve91 &raquo;</TD></TR><TR><TD CLASS="quote">It gives 3/4" more travel. I've confirmed that with GC.
is it worth it for HPDE;s?
Old Feb 9, 2004 | 09:32 PM
erikiksaz1's Avatar
Default Re: Ground control upper mounts, how much extra suspension travel? (GraphiteAccord)
what's HPDE's?
Old Feb 9, 2004 | 09:38 PM
Tyson's Avatar
an EG owner with Koni's with the username VX said he measured just shy of 3/4". thats a significant amount of shock travel because it multiplies when you translate it to extra wheel travel since the shock is a bit more inboard. is it worth it? are you low enough that youre riding on your bumpstops, then yes, definately. $75 isnt too much unless you already can weld your own mounts or, dont mind altering your shock and do the lower fork mod. both accomplish the same thing.
Old Feb 9, 2004 | 09:41 PM
erikiksaz1's Avatar
Default Re: Ground control upper mounts, how much extra suspension travel? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">an EG owner with Koni's with the username VX said he measured just shy of 3/4". thats a significant amount of shock travel because it multiplies when you translate it to extra wheel travel since the shock is a bit more inboard. is it worth it? are you low enough that youre riding on your bumpstops, then yes, definately. $75 isnt too much unless you already can weld your own mounts or, dont mind altering your shock and do the lower fork mod. both accomplish the same thing.</TD></TR></TABLE>
And using the older generation Accord shocks also adds more travel
https://honda-tech.com/zerothread?id=399992
https://honda-tech.com/zerothread?id=469161
Old Feb 9, 2004 | 10:00 PM
Lo-Buck EF's Avatar
woops. thats what i ment
Rob.
Suspension & Brakes
Jul 11, 2009 12:22 AM
turbotime
Jul 13, 2004 10:44 PM
deviant1
Feb 29, 2004 09:27 AM
j-robsDA
Jan 24, 2004 08:20 PM
CXHatchback
29
Mar 11, 2003 05:34 PM
