gsr resistor box?
Old Feb 9, 2004 | 05:34 PM
Tim_go_fast's Avatar
Default gsr resistor box?
im doing a b series swap in my EK and i was wondering if the GSR uses a resistor box????
Old Feb 9, 2004 | 07:42 PM
VTECVillain's Avatar
Default Re: gsr resistor box? (Tim_go_fast)
GSR engines/ECU's are not designed around peak/hold injectors with a resistor box. They run saturated injectors without a resistor box as do most OBD1-OBD2 setups. So the answer is no you don't need a resistor box.
Old Feb 9, 2004 | 07:44 PM
thank you
myst0ryman
Mar 31, 2006 07:40 PM
redboost10
Oct 23, 2003 03:35 PM
