i have a trany question
Old Feb 9, 2004 | 05:31 PM
jdm_gsr's Avatar
Default i have a trany question
i have a gsr tranny and its missin second gear can i put a ls second gear in to teh gsr trannnny and will the ls chasising fit the gsr tranny
Old Feb 10, 2004 | 01:49 AM
JDMH22HATCH's Avatar
Default Re: i have a trany question (jdm_gsr)
LS casings and B16 casings are the same. I believe the GSR casing uses different shims for the diff, but I'm not positive. If so, just swap the shims from the diff to the case you are going to use. Somebody please correct me if I'm wrong
Old Feb 10, 2004 | 08:53 AM
jdm_gsr's Avatar
WHAT ABOUT THE GEARS I HEARD FIRST AND SECOND ARE CONECTED TO TEH SHAFT ORRR WHAT IF I TAKE THE THIRD THRU 5TH FROM THE GSR TRANNY AND PUT IT INTO TEH LS TRANNY
Old Feb 10, 2004 | 11:02 AM
Default Re: (jdm_gsr)
Man I hate all caps. The reason why I didn't answer that parts was cause I wasn't definite. But I'm pretty sure they cant be switched. I thinkg the only one that can be switched is the final drive.
Old Feb 10, 2004 | 03:31 PM
acy76's Avatar
Default Re: (JDMH22HATCH)
You could probably get away with replacing the countershaft side 2nd gear and/or synchro set on the GSR trans and leaving it at that. Less work that way.
Old Feb 10, 2004 | 07:37 PM
jdm_gsr's Avatar
so what does that mean put the gears into the gsr trany or ls
Old Feb 11, 2004 | 05:55 AM
acy76's Avatar
Have you got the whole transmission or just the gearset? If you have the whole gearbox, I would just fix what's broken.
JDM_Certified
Transmission & Drivetrain
Jun 26, 2010 11:54 PM
NickW
Feb 28, 2005 09:17 AM
Nextelbuddy
May 24, 2004 09:16 AM
Jonathan_ED3
Apr 19, 2002 12:06 AM
Allstar
Oct 24, 2001 09:41 PM
