help me out with this little problem
i got this jumper harness from a member on hondatech its a 99-00 OBD2 to OBD1 made by blown90hatch ...i need a little help becasue its not fittin in right...i think i got the worse one ....are their two different versions?...please help..thanks
whats the differences between obd2b to obd1 harness and obd2b to obd2a?...because tryin to run a p 28ecu..and i got a 99 teg gsr..HELP.
You would need an OBD-2B to OBD-1 conversion harness. Is it tough to insert the sockets or is it not fitting at all?
OBD-2B on the left and OBD-2A on the right. See if the socket patterns match to the right one on your harness.
I don't remember if the '99 Integra's were OBD-2A or -2B. Look at your ECU and compare it to the picture. That'll tell you....or just look at where the blank spot is.
its obd2b. you were right in your last post. blown90hatch used factory sockets for both his old/new so fitment woulnt be an issue if you used the correct harness
jdmdikk
Apr 15, 2009 07:55 AM
boost and bass
Jan 22, 2009 08:42 PM
