B18C5 into a DB1?(or DA)
Old Feb 9, 2004 | 04:11 PM
Blazeone's Avatar
Default B18C5 and ITR exhaust into a DB1 Integra?(or DA)
I was wonder how hard it would be to put a 2000 USDM B18C5 into my 1990 DB1 4 door integra? The car is already wired for OBD1.
I was also wondering if the ITR exhaust would bolt up to the 4 door?
Old Feb 9, 2004 | 04:24 PM
toohott4handlin's Avatar
Default Re: B18C5 and ITR exhaust into a DB1 Integra?(or DA) (BlazeONE)
It bolts right in. You will need however, a cable vtec transmission (hydro tranny wont work) obd 1 vtec ecu, obd 1 distributer, wire for vtec selenoid, knock sensor, and a few various hoses and such. A b18c5 is obd2 though, so you will need to make it obd1.
Old Feb 9, 2004 | 04:36 PM
Blazeone's Avatar
Default Re: B18C5 and ITR exhaust into a DB1 Integra?(or DA) (toohott4handlin)
I planned on getting the Hydro tranny conversion.
Would it be way to much from going OBD1 to OBD2?
Old Feb 9, 2004 | 06:02 PM
FlaN.'s Avatar
just switch it over to obd1, why would u want obd2?
Old Feb 9, 2004 | 09:04 PM
Slain's Avatar
to my knowledge no one has made a tranny conversion for the 2nd gen. rumors had it that HAS or place racing were making one but havent ever seen one. easier to route would be to get a vtec cable tranny might as well spend a little more and get one with a oem lsd.
Old Feb 9, 2004 | 09:59 PM
Blazeone's Avatar
Default Re: (theJUMPoff)
Because i already have the ECU and everything OBDII...
****, no LSD with jdm final, shitty
Ill call place racing up and see whats up.
What vehicles did they make the hydro conversion for?
Old Feb 10, 2004 | 01:03 AM
FR-MOB: ThE bEe GuY's Avatar
Default Re: (BlazeONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlazeONE &raquo;</TD></TR><TR><TD CLASS="quote">Because i already have the ECU and everything OBDII...
What vehicles did they make the hydro conversion for?</TD></TR></TABLE>
To my knowledge only HASport has made a Cable to Hydro conversion, and that was only for EF's. I hope someones comes our with one for a DA, i'll get one in a heartbeat.
Old Feb 10, 2004 | 12:17 PM
Slain's Avatar
I agree if there is indeed a conversion i'd hop on one in a instant too. Only rumors and speculations &lt;shrugs&gt;
Old Feb 10, 2004 | 12:19 PM
SOL1D's Avatar
Default Re: (Slain)
If you can get your hands on a 92-93 ys1 manual tranny, you can put all the gears from a ITR hydro tranny into a that ys1 cable tranny with a VERY little mod
Old Feb 10, 2004 | 02:04 PM
thejunkman's Avatar
Default Re: (SOL1D)
someone on G2ic did that... a little grinding involved?
Old Feb 12, 2004 | 11:43 AM
Slain's Avatar
you have to shave inside the tranny casing.
Old Feb 12, 2004 | 11:50 AM
Jasper_db1's Avatar
Default Re: (Slain)
If it works for an EF, I don't see why it won't work for a DA. I still wouldn't go that route though. There's nothing wrong with a VTEC YS1.
Old Feb 12, 2004 | 01:26 PM
Default Re: (Jasper_db1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">If it works for an EF, I don't see why it won't work for a DA. I still wouldn't go that route though. There's nothing wrong with a VTEC YS1.</TD></TR></TABLE>
THe Hydro kit wont work for a DA because the one for EF's is made to drop a Bseries Hydro tranny into an engine bay meant for a Cable SOHC motor. So While it allows the use of a Hydro tranny, it also changes the location on the tranny mount because the stock engine was SOHC
Old Feb 12, 2004 | 01:49 PM
TEXN3's Avatar
didn't zoom do the changeover to a hydro tranny?
i'm sure if you searched on http://www.g2ic.com for a bit, you would find it.
also, what trans is dan(g2guru) using with his b18c5?
Old Feb 12, 2004 | 02:00 PM
red civic standard's Avatar
Default Re: (texnteg)
Gabe_ on this board is in the process of putting a JDM R into his DA.
He is using the cable GSR YS1 tranny with a Quaife LSD and running the motor OBD1. You can use all the OBD2 electronics (distributor, injectors, o2), but just run them OBD1 (required some cutting a splicing).
Old Feb 12, 2004 | 06:15 PM
Gabe_'s Avatar
Default Re: (red civic standard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">Gabe_ on this board is in the process of putting a JDM R into his DA.
He is using the cable GSR YS1 tranny with a Quaife LSD and running the motor OBD1. You can use all the OBD2 electronics (distributor, injectors, o2), but just run them OBD1 (required some cutting a splicing).</TD></TR></TABLE>
Yes I am... the GSR YS1 has comparable gearing to the ITR tranny... and with the Quaife, I think it will be on par. Everything should be in the car within the next month or two. I will post up some pics when I get it all running.
Old Aug 18, 2005 | 08:49 PM
victus's Avatar
Default Re: (FlaN.)
How did all this turn out for you.
Now I have your questions
Lmgrcivic
Oct 16, 2010 01:03 PM
vtizzle
Engine Management and Tuning
Apr 23, 2009 12:04 AM
m1ch431_g
Oct 6, 2004 09:11 PM
SOJAMR1
Feb 15, 2003 12:01 PM
SuperMan19
Dec 17, 2002 05:34 PM
