short shifter install
Old Feb 9, 2004 | 02:47 PM
Curtis2kul's Avatar
Default short shifter install
Does anyone have instructions or some tips for installing a short shifter in a 89 civic. Any help would be appreciated
Old Feb 9, 2004 | 03:33 PM
sp3a12uk's Avatar
Default Re: short shifter install (Curtis2kul)
diffrent car same thing. (pics)
Heres a link http://www.overboost.com/story.asp?id=360
Old Feb 9, 2004 | 03:53 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: short shifter install (sp3a12uk)
good link...
Inside the car,unscrew the shift ****..
under the car,take out the bolts/nuts as numbered..
Old Feb 9, 2004 | 04:48 PM
crashtest Sonny's Avatar
Default Re: short shifter install (88DXCRX)
i hate it when the linkage hits the exhaust pipe when you have a short shifter. im going to take mine out and go with the stock.
Old Feb 9, 2004 | 04:56 PM
EL Vap133's Avatar
Default Re: short shifter install (crashtest Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashtest Sonny &raquo;</TD></TR><TR><TD CLASS="quote">i hate it when the linkage hits the exhaust pipe when you have a short shifter. im going to take mine out and go with the stock. </TD></TR></TABLE>
Next time get your exhaust done at a real place....
Old Feb 9, 2004 | 05:03 PM
Default Re: short shifter install (EL Vap133)
tell your uncle to hook me up then!
Old Feb 9, 2004 | 05:10 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashtest Sonny &raquo;</TD></TR><TR><TD CLASS="quote">tell your uncle to hook me up then! </TD></TR></TABLE>
I will if you don't crash on the way over there....
Old Feb 9, 2004 | 05:13 PM
dang..ill try not to!
Old Feb 10, 2004 | 05:57 AM
ijjz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Next time get your exhaust done at a real place.... </TD></TR></TABLE>
No kidding..
Those 2 and 3 nuts were a bitch on my car when i first undid them last year.
Good luck.
Old Feb 10, 2004 | 10:33 AM
canadiancoch's Avatar
Default Re: short shifter install (ijjz)
anyone know the sizes? and did anyone have to unbolt the exhaust piping, because mine looks like it's in the way.
Dr.
Old Feb 10, 2004 | 11:03 AM
crxtreme89h's Avatar
Default Re: short shifter install (canadiancoch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canadiancoch &raquo;</TD></TR><TR><TD CLASS="quote">anyone know the sizes? and did anyone have to unbolt the exhaust piping, because mine looks like it's in the way.
Dr.</TD></TR></TABLE>
You shouldn't need to unbolt anything on the exhaust. You may want to drop it down though. There are usually little rubber bungees holding the exhaust pipe up.
Old Feb 10, 2004 | 01:44 PM
onePOINTsix's Avatar
Default Re: short shifter install (crxtreme89h)
almost all bolts on a honda are 10mm, 12mm or 14mm. have all those sockets handy
Old Feb 10, 2004 | 01:49 PM
^jefs0ng's Avatar
Banned
I will if you don't crash on the way over there.... </TD></TR></TABLE>
Word? Uncle=piping? How much if I bring a sac of oreos REGULAR stuf?
Old Feb 10, 2004 | 03:01 PM
B2FiNiTY's Avatar
Default Re: short shifter install (#jefs0ng)
I just did a shifter install and these are the tools you need:
3/8 ratchet is best
12mm socket
12mm open end wrench
flat heat or fat pliers to hold down the bolts from the cabin
Old Feb 10, 2004 | 03:55 PM
kim_2_da_chee's Avatar
Default Re: short shifter install (B2FiNiTY)
a bushing kit will also make your shifts feel nice and solid
Old Feb 10, 2004 | 05:59 PM
KuunLB's Avatar
Default Re: short shifter install (kim_2_da_chee)
i only took the bold for the shift linkage and the 2 holding the assembly in place out. i didn't take all thor other out, you just unbolt the 3 main ones and kinda wiggle it out past the pipe.. took an hour to get everything done
question, did anyone put lube in the socket the shifter goes in? i noticed today my squeaks a bit.. thinkin i may need some lube, any ideas?
nicoya_hyphy@yahoo.com
Sep 7, 2007 08:26 PM
puertoroc7976
Sep 18, 2006 11:43 AM
ProjectCD5
Feb 21, 2006 11:55 PM
crxzc
Jul 2, 2002 05:09 AM
chrisv76
Mar 1, 2002 10:21 AM
