My Gsr isnt turnin over, may be ignition problem
I have a problem with my 94 gsr. For some reason the engine will not turn over. My battery is fine. I pulled the spark plugs to see if was getting spark and im not. I did replace the spark plugs but I'm guessing its an ignition problem. Its been really cold where i live. what do you think?
-pete
Modified by Pwolf at 11:47 PM 2/9/2004
-pete
You should check your battery terminals. My 92' would not turn over one cold day and sure enough the + terminal was loose enough to wiggle off. I would try spinning the terminals on the posts of the battery, I they spin, that is your problem. Just loosen the terminal and take plyers and crimp the original terminal to fit tighter. See if that works.
