z6 in rex quetions
alright guys the build up is going to start soon but i need more info and i don't want to jump in to this half way and there be a major problem (there are always small things) the motor is going to be a d16z6 with a1 pistons, small cam all the compononts need for the cam, p&p head. i don't know what i am going to need for fuel manag.(let me know what i need) ecu i not sure what i going to do yet with the p28. Also i need a obd1 to 0 conversion and a hydro to cable. this is going into a 90-91crx si if i have neglected anything let me know.
Why do you want hydro-to cable for are you talking mounts or something?
Elaborate on what your trying to say man.
List things for us dummys who cant read to well
i have a d16z6 which has a hydrualic clutch the crx has a cable activated clutch so i would need a conversion i thought, but i coud just get a diffrent tranny like the one that is on the crx rigth now because they are both d motors.
if you have an si then use that tranny with your z6. Use your old motor mounts and bolt the z6 in. I would go with the obd0-obd1 conversion and run the p28. For a mild setup just get an fpr and a vafc, it should be enough tuning for a simple build.
badfish311
Transmission & Drivetrain
May 18, 2012 08:16 AM
almostjdmeg
Jan 30, 2008 06:41 PM
SteyrTMP
May 25, 2005 11:17 PM
